Battery to battery straight wire of current?
  • Context: Undergrad
  • Thread starter Thread starter DocZaius
    Battery Current Wire
The discussion centers on the feasibility of creating a steady current by connecting the positive terminal of one 9 V battery to the negative terminal of another 9 V battery. It concludes that this setup does not produce a steady current due to the accumulation of charge at the battery terminals, which prevents a closed circuit. The Biot-Savart Law is referenced to understand the expected magnetic field around the wire, but the practical implementation fails because the circuit is incomplete.
  • Understanding of the Biot-Savart Law
  • Basic knowledge of electric circuits
  • Familiarity with battery characteristics and behavior
  • Concept of closed circuits and current flow
  • Research the principles of closed circuits in electrical engineering
  • Study the Biot-Savart Law in detail for practical applications
  • Explore battery charging and discharging dynamics
  • Learn about circuit design to prevent charge accumulation
Students and enthusiasts in physics, electrical engineering, and anyone interested in practical applications of circuit theory and magnetic fields.
DocZaius
While I was looking at an example of the Biot-Savart Law for a finite, straight wire of current, I started considering whether one can easily create one in practice.
If I hooked up the positive terminal of a 9 V battery by a resistance to the negative terminal of another 9 V battery, would there be a steady current? If so, if I then tested the space around it with a magnetometer, would I roughly get the magnetic field intensities around the wire that I'd expect from the math?
The main issue I see with a battery to battery hookup would be the fast accumulation of charge in one of the batteries - which isn't an issue for a circuit current from a single battery (the battery itself remains neutral in that case).
I understand this question is more practical than theoretical, and I apologize if it's asked in the wrong forum.
Yor system wouldn't work because it isn't a closed circuit. Charges will pile up at the end of both batteries (in a short time) and there will not be a steady charge flow (current).
  • · Replies 36 ·
  • · Replies 105 ·
14K
  • · Replies 17 ·
