If Logb(x) = 0.8, solve for Logb(x)(x^1/3)
  • Thread starter Thread starter srizen
The discussion revolves around a logarithmic expression involving the variable x, specifically given the condition that \(\log_b x = 0.8\). Participants are tasked with evaluating \(\log_b(x \sqrt[3]{x})\) based on this information.
  • Participants explore the relationship between logarithmic properties and the expression involving both x and its cube root. There are attempts to rewrite the expression in terms of a single logarithm and to clarify the intended structure of the problem. Some participants express confusion over the notation and the clarity of the problem statement.
There is an ongoing exploration of how to manipulate the logarithmic expression, with some participants suggesting rewriting it to facilitate evaluation. A few participants have noted the potential for misunderstanding due to the problem's presentation, while others have begun to clarify their interpretations.
Some participants mention the lack of clarity in the problem statement, indicating that the notation used may have led to confusion regarding the argument of the logarithm. Additionally, there is acknowledgment that the variable b is not provided, which complicates the evaluation process.
srizen
i got a question on a quiz, but i really did not know how to solve it. the question that was stated was:
if [itex]\log_b x =0.8[/itex]
Solve for
[itex]\log_b x(\sqrt[3]{x})[/itex]
basically what i attempted to do was
b0.8 = x
Logb x + Logb 3√x
Logb x + 1/3Logb x
0.8 + 1/3Logb x ?EDIT:
picture attachment
formatting
if Logbx = 0.8
Solve for
Logbx(3√x)
You're not solving for anything - you are evaluating this expression.
In any case, is that what you're working with?
[tex]log_b(x \sqrt[3]{x})[/tex]
If so, that's different from what you wrote.
Make Logbx = 0.8
into b0.8 = x
then i didn't know what to do ;S.
what steps do i need to do?
how do i solve for b/x?
hmm, let me scan it, i don't know how to do all these math symbols
I assume you mean [itex]log[/itex][itex]_{b}[/itex][itex]x[/itex][itex]\sqrt[3]{x}[/itex]?
Try to get it so you have [itex]klog[/itex][itex]_{b}[/itex][itex]x[/itex], [itex]k[/itex] [itex]constant[/itex]
Try to rewrite the expression
[itex]\log_b(x \sqrt[3]{x})[/itex]
as a single power, ie.
[itex]\log_b(x^a)[/itex]
for some number a. You'll then need the power property of logarithms.
that would be simple, but its
[itex]\log_b x( \sqrt[3]{x})[/itex]
Use the relationship
[itex]x[/itex][itex]^{\frac{1}{a}}[/itex] = [itex]\sqrt[a]{x}[/itex]
And [itex]x^{a}[/itex][itex]x^{b}[/itex] = [itex]x^{a+b}[/itex]
If it's supposed to be in that form as the question asks, which I suppose should mean
[tex](\log_bx)(\sqrt[3]{x})[/tex]
Then simply plug in 0.8 into the first bracket since you're already given that, and solve for x in [itex]\log_bx=0.8[/itex] to find [itex]\sqrt[3]{x}[/itex]
yea that's my question, how do you solve for x
when ur given 2 variables?
b is not given :S
heres what I am doing so far:b0.8 = x
Logb x + Logb 3√x
Logb x + 1/3Logb x
0.8 + 1/3Logb x ?
b is not given :S
b0.8 = x
Logb x + Logb 3√x
Logb x + 1/3Logb x
0.8 + 1/3Logb x ?
That's right. You know [itex]log_{b}x[/itex] = 0.8, so sub that in.
the only problem is that, the answer should be 1.07 =/
b is not given :S
Logb x + Logb 3√x
Logb x + 1/3Logb x
0.8 + 1/3Logb x ?
Ok so it IS meant to be [tex]log_b(x\sqrt[3]{x})[/tex] as opposed to [tex](log_bx)\cdot \sqrt[3]{x}[/tex]
Yes, the answer is 1.07, what's the problem? 0.8 + 1/3*0.8 = ?
ohh, ok i see my mistake now :S
this is such an easy problem, i was jus over thinking >_<
Whoever wrote this problem did not communicate the problem in a clear way. The only way we could understand what was written was to reverse-engineer the solution. The problem should have been written so that it was clear what the argument of the log function was.
Yep :wink:
I was about to ask for the solution if the OP didn't already provide it. This confusion was unnecessarily getting out of hand...
edit: the answer was written in the attachment. To be honest, it looked like effort to try and understand what was happening on that page so I gave up!
  • · Replies 17 ·
