Show the iterates of tan(x)/2 converge to 0
  • Thread starter Thread starter razmtaz
The problem involves the function f(x) = tan(x)/2 and requires showing that the iterates of x converge to 0 for x in the interval (-pi/3, pi/3). This is situated within a course context focused on chaos and fractals.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the mean value theorem to establish inequalities related to the function. There is an exploration of whether f(x) < x can be shown for the specified interval, with some participants expressing uncertainty about their approaches. Others question the implications of a decreasing sequence and whether it necessarily converges to 0.
Some participants have provided insights into the behavior of the function and its iterates, noting that the sequence is decreasing and bounded below by 0. There is a suggestion that the fixed point at 0 may be attracting, leading to further exploration of the implications of this property. However, there is no explicit consensus on the overall conclusion regarding convergence.
Participants note the importance of the interval (-pi/3, pi/3) and the implications of the function's monotonicity. There is also mention of the limitations of graphical methods in formal proofs and the need for rigorous algebraic justification.
razmtaz
let f(x) = tan(x)/2. show the iterates of x converge to 0 whenever x is in (-pi/3, pi/3)
(note this is for a course in chaos/fractals)
A similar problem in the book used mean value theorem which says that for a function continuous on [a,b] and differentiable on (a,b), there exists c such that: f'(c) = (f(b)-f(a))/b-a
First of all, tan(-x) = -tan(x) for the given interval so I restrict the problem to [0,pi/3)
also tan(0) = 0 so restrict the interval further to (0,pi/3)
now we want to show that the iterates of the function (ie the sequence {f(x), f(f(x)), f(f(f(x))), ...} ) converges to zero for the given interval
I used the mean value theorem as was done in the textbook in hopes of getting down to tan(x)/2 < x so that I can say f[n+1](x) = f(f[n](x)) = tan(f[n](x))/2 < f[n](x) so that I can then conclude that every iterate of the function is less than the previous one, and since the function is bounded below by 0 (on our interval) I can finally conclude that the iterates converge to 0.
First question: Would you fine people be convinced that:
since tan(x) is strictly increasing on the given interval, and since tan(pi/3)/2 < pi/3 then tan(x)/2 < x for the given interval? If so, I think I can proceed as I've outlined above.
If not, here is how I've proceeded with MVT, on interval (0,x):
f'(c)(b-a) = f(b)-f(a)
-> ((sec^2(c))/2) * (x-0) = tan(x)/2 - tan(0)/2 = tan(x)/2
then on the interval (0,pi/3) I get:
1/2 < sec^2(x)/2 < 2
-> x/2 < x*sec^2(x)/2 = tan(x)/2 < 2x
And now I am stuck because I can't get tan(x)/2 < x
I can, however, get x/4 < tan(x)/4 < x
which, using the method I wanted to above, would give me:
f[n+1](x) = f(f[n](x)) = 1/2 *tan(f[n](x))/2 < f[n](x)
but I am not sure that 1/2 *tan(f[n](x))/2 < f[n](x) is a strong enough statement to conclude that the iterates of tan will always be decreasing.
Any hints, help, insight, comments, corrections, etc... are welcomed.
thanks for you help.
EDIT: Is this (showing f(x) < x) a good method to use when attempting to show that the iterates of an arbitrary function converge to a specific value in a specific interval? Is there a standard way to attempt such a problem?
That inequality is certainly true! But your proof that it is true (that you stated later) is not correct. It is not enough to show tan(x)/2 is increasing. You should try finding another proof of this.
No. Now you proved that the sequence [itex](f^{(n)}(x))_n[/itex] is decreasing and bounded below by 0. This does NOT mean that the sequence actually converges to 0!
For example: [itex]1+\frac{1}{n}[/itex] is bounded below by 0 and is decreasing. But it converges to 1.
However, it is a good first step. Indeed, you've proven it to converge. Let y be its limit. Try to prove that y is a fixed point of f. I.e. that f(y)=y.
Thanks for the reply micromass.
Okay, well, if I evaluate f at 0 I get zero, which is the definition of a fixed point. Are you asking me to show that tan(x)/2 is 0 at 0, or are you asking me to try and show that f[n](0) = 0?
Okay, so i tried a few times and i was unable to show algebraically that tan(x)/2 < x for (0,pi/3).
To solve the problem I ended up graphing the two with maple and observing that tan(x)/2 < x is true. Then i used a corollary in my textbook which says that if a sequence is bounded and monotone then it converges to a fixed point; then i see that tan(0)=0 so 0 is the fixed point which the sequence converges to.
Not sure how legit this technique of graphing is (if I were writing an exam I wouldn't be able to do it) so at this point I am looking for any hints:
I want to show that for f(x) = tan(x)/2, the sequence {f[n](x)} from n = 0 to infinity (that is, {f(x), f(f(x), f(f(f(x))), ...}) is decreasing, then I can take care of the rest of the question using the corollary from the text
so we want to find the interval where f(x)<x, as a start we know
[tex]f(x)=\frac{1}{2}tan(x)[/tex]
[tex]f'(x)=\frac{1}{2}sec^2(x)\frac{1}{2cos^2(x)}[/tex]
both f & f' are monotonically increasing functions on [0,pi/2) with
[tex]f(0)=0[/tex]
[tex]f'(0)=\frac{1}{2}[/tex]
[tex]f(\pi/3)= \frac{1}{2}\frac{sin(\pi/3)}{cos(\pi/3)}= \frac{1}{2}\frac{\sqrt{3}}{2}\frac{2}{1}= \frac{sqrt{3}}{2}[/tex]
This, with f(0)=0 and being monotinically increasing, is enough to show f(x)<x on [0,pi/3] and using tan(-x)=-tan(x) extends the iteration to [-pi/3,pi/3]
In fact tan(x)/2<x on the interval 0 to where tan(x)=2x which does not have an analytical solution, but is ~1.16>pi/3~1.047
Call f applied n times f_n. Are you sure you have to prove f_n(x) converges to 0?
If so here's a real rough sketch idea
Assume for 0<x<b, that 0<f(x)<x and f(0)=0.
The sequence given by f_n(x) is monotonically decreasing and bounded below by zero
Now, assume lim n-> inf, f_n(x)=c>0,
But by def'n f(c)<c which is a contradiction
Yeah, the problem asks for that specifically, but its restricted to the interval (-pi/3, pi/3).
I wonder if there is a much easier way to solve this. We have a theorem in the text that says "suppose f is differentiable at a fixed point p. then if |f'(p)| < 1 then p is an attracting fixed point..."
We know that 0 is a fixed point, and f'(0) = 1/2 so 0 is an attracting fixed point, so can I conclude that f_n will tend to 0 as n tends to infinity? The only reason I am not sure is because there could be other fixed points in the region, but since you showed that tan(x)/2 < x for (0,pi/3) then there can't be any other fixed points in the region. This seems right to me, what do you think?
Note that an attracting fixed point of a function f is a point p such that f(p) = p and f_n(p) -> p as n -> infinity, which is really close to what I am trying to show
The sketch shows that any starting point for a sequence tends to zero, so I think we've done enough. Though you will need to flesh out the monotonicity. You could add in that any bounded
That theorem you quote applies to the behaviour in the nighbourhood of the fixed point. So it shows your point is attracting, but says nothing about the global interval that will be attracted.
  • · Replies 40 ·
