Tension in string attached to two fixed points
The discussion centers on calculating the temperature at which the tension in a steel wire, initially at 120N at 0 degrees Celsius, becomes zero. The key concept involved is Young's Modulus, which relates tension to elongation in materials. The formula used is λ = T/A_wire * (x/L_wire), where T is tension, A_wire is the cross-sectional area, x is the change in length, and L_wire is the original length. By determining the elongation required to relieve the tension, one can calculate the necessary temperature increase for the wire to expand sufficiently.
  • Understanding of Young's Modulus in materials science
  • Basic knowledge of tensile stress and strain
  • Familiarity with thermal expansion concepts
  • Ability to perform calculations involving area and length of materials
  • Research Young's Modulus values for various materials, focusing on steel
  • Learn about thermal expansion coefficients for metals
  • Study the relationship between tension and elongation in wires
  • Explore practical applications of tensile strength in engineering
This discussion is beneficial for physics students, materials engineers, and anyone involved in mechanical design or structural analysis, particularly those dealing with tension in materials.
fluz
I'm having trouble with this physics problem:
A piece of steel wire (diameter 2mm) is connected between two fixed points. The tension in the wire is 120N at 0 degrees celsius. At what temperature is the tension 0?
I assume that I first have to calculate how much "too short" the string is (thus creating tension), and after that calculate how much the temperature has to rise for the wire to expand that much.
My problem is that I don't know how the wire length relates to the tension. Can someone point me in the right direction, please?
This looks like a Young's Modulus problem:
[tex]\lambda = \frac{T/A_{wire}}{x/L_{wire}}[/tex]
You can work out the ratio x/L from the tension if you look up Young's modulus for steel. Then work out the temperature that would cause the string to expand that amount.
AM
Andrew Mason, you are just smart!
hhegab
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 17 ·
