Angular speed question right away
The angular speed of a pencil, treated as a uniform rod, just before it hits the table is calculated to be 16.8 rad/s. This conclusion is derived using the conservation of energy principle, equating potential energy (PE) at the height of 15.7 cm to kinetic energy (KE) just before impact. The potential energy is calculated using PE = mgh, with m approximated as 0.01 kg and g as 9.8 m/s². The moment of inertia for the pencil is determined using I = 1/12mL², leading to the final angular speed calculation.
  • Understanding of conservation of energy principles
  • Familiarity with potential energy and kinetic energy formulas
  • Knowledge of moment of inertia for uniform rods
  • Basic understanding of angular motion concepts
  • Study the conservation of energy in rotational systems
  • Learn about the moment of inertia for different shapes
  • Explore angular motion equations and their applications
  • Investigate real-world examples of rotational dynamics
Students in physics, educators teaching mechanics, and anyone interested in understanding rotational dynamics and energy conservation principles.
apgym2
angular speed question! please help right away!
a pencil, 15.7 cm long, is released from a vertical position with the eraser end resting on a table. The eraser does not slip. Treat the pencil like a uniform rod. what is the angular speed of the pencil just before it hits the table?
i know i have to use conservation of energy, but I am not sure where center of mass fits in.. please help
the answer choices are:
a. 11.2 rad/s
b. 7.23 rad/s
c. 24.5 rad/s
d. 16.8 rad/s
any help or guidance would be much appreciated..thank u!
In figuring the change of PE of the pencil, use the change in height of the center of mass. The PE gets converted to rotational KE.
To solve this problem, we can use the conservation of energy principle, which states that the total energy of a system remains constant. In this case, the pencil has potential energy at the top of the table and kinetic energy just before it hits the table. We can equate these two energies to find the angular speed of the pencil.
First, we need to find the potential energy of the pencil at the top of the table. The potential energy of an object at a certain height is given by the formula PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height.
In this case, the height of the pencil is the length of the pencil, 15.7 cm. The mass of the pencil is not given, but we can assume it is a standard pencil with a mass of about 10 grams (0.01 kg). The acceleration due to gravity is 9.8 m/s^2. Plugging these values into the formula, we get PE = (0.01 kg)(9.8 m/s^2)(0.157 m) = 0.0154 J.
Next, we need to find the kinetic energy of the pencil just before it hits the table. The kinetic energy of an object in motion is given by the formula KE = 1/2Iω^2, where I is the moment of inertia and ω is the angular speed.
Since the pencil is treated as a uniform rod, its moment of inertia can be calculated using the formula I = 1/12mL^2, where m is the mass and L is the length of the rod. Plugging in our values, we get I = (1/12)(0.01 kg)(0.157 m)^2 = 0.0000205 kgm^2.
Now, we can equate the potential energy and kinetic energy to find the angular speed. 0.0154 J = 1/2(0.0000205 kgm^2)ω^2. Solving for ω, we get ω = √(2(0.0154 J)/(0.0000205 kgm^2)) = 16.8 rad/s.
Therefore, the correct answer is d. 16.8 rad/s.
In terms of the center of mass, it is not necessary to consider it in this problem since the pencil is
  • · Replies 20 ·
