Energy of homogenously charged sphere
The discussion centers on the energy of a homogenously charged sphere, comparing it to that of a conducting charged sphere. Participants explore the derivation of the energy formula for the homogenously charged sphere and the origin of the factor 3/5 in the equation.
  • Technical explanation, Debate/contested, Mathematical reasoning
  • One participant states the energy of a conducting charged sphere is given by E=Q²/(8ε₀πr) and questions the origin of the 3/5 factor in the energy formula for a homogenously charged sphere, E=3/5*Q²/(ε₀πr).
  • Another participant provides a detailed derivation of the energy in the electrostatic field of the sphere, referencing Maxwell's equations and the potential formulation, but notes a missing factor of 4π in the original calculation.
  • A third participant expresses a different understanding of the divergence of the electric field and potential formulation, suggesting a correction to the equations presented.
  • Subsequent replies discuss typographical errors in the equations and the implications for the calculations, with one participant acknowledging the mistake regarding the factor of 4 in the denominator.
  • There is a suggestion to seek further clarification from another participant, Gavroy, regarding the source of the equation.
Participants do not reach a consensus on the derivation of the energy formula for the homogenously charged sphere, and multiple viewpoints regarding the equations and their corrections remain present.
There are unresolved typographical errors in the equations discussed, and the derivation relies on specific assumptions about the electric field and potential that are not fully clarified.
Gavroy
hi
i know that the energy of a conducting charged sphere is E=Q²/(8epsilon_0*pi*r) and i know how to calculate this.
now i found that a homogenously charged sphere has E=3/5*Q^2/(epsilon_0*pi*r).
does anybody have an idea how to calculate this? i don't know where this 3/5 come from?
What you have there is the energy in the electrostatic field of the sphere. This one you need first. You get it from the corresponding Maxwell equations for static fields,
[tex]\vec{\nabla} \cdot \vec{E}=\frac{\rho}{\epsilon_0}, \quad \vec{\nabla} \times \vec{E}=0.[/tex]
[The above is corrected for typos according to #3; thanks for pointing them out!]
From the second equation you see that the electrostatic field is a potential field, i.e.,
[tex]\vec{E}=-\vec \nabla \Phi.[/tex]
Substituting this into the 2nd equation yields\
[tex]\Delta \Phi=-\frac{\rho}{\epsilon_0}.[/tex]
Now you have
[tex]\rho(\vec{x})=\begin{cases} \rho_0=\frac{3Q}{4 \pi R^3} & \text{for} \quad r=|\vec{x}<R|\\ 0 & \text{for} \quad r \geq R. \end{cases}.[/tex]
Due to symmetry, [itex]\Phi[/itex] depends only on [itex]r[/itex] and thus writing the Laplacian in spherical coordinates for [itex]r<R[/itex] leads to
[tex] \frac{1}{r} \frac{\mathrm{d}}{\mathrm{d} r^2} [r \Phi(r)]=-\rho_0.[/tex]
From this you get
[tex]\epsilon_0 [r \Phi(r)]''=-\rho_0 r \; \Rightarrow \; \epsilon_0 [r \Phi(r)]'=-\frac{\rho_0}{2} r^2+C_1 \; \Rightarrow \; \Phi(r)=-\frac{\rho_0}{6 \epsilon_0} r^2+C_1+\frac{C_2}{r}.[/tex]
Since for [itex]r=0[/itex] the potential should be regular, we must have [itex]C_2=0[/itex].
For [itex]r>R[/itex] the same calculation leads to
[tex]\Phi(r)=\frac{C_3}{r},[/tex]
where we have determined one constant such that [itex]\Phi(r) \rightarrow 0[/itex] for [itex]r \rightarrow \infty[/itex]. The constant, [itex]C_3[/itex], is determined by Gauss's Law to be [itex]C_3=Q/(4 \pi \epsilon_0)[/itex].
Continuity at [itex]r=R[/itex] leads to
[tex]-\frac{Q}{8 \pi \epsilon_0 R}+C_2=\frac{Q}{4 \pi \epsilon_0 R}[/tex]
i.e.
[tex]C_2=\frac{3 Q}{8 \pi \epsilon_0 R}.[/tex]
For the total energy of the electric field you find
[tex]\mathcal{E}=\frac{\epsilon_0}{2} \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} \vec{E}^2(\vec{x})=\frac{1}{2} \int_{\mathbb{R^3}} \mathrm{d}^3 \vec{x} \rho(\vec{x}) \Phi(\vec{x}).[/tex]
This gives from our above result
[tex]\mathcal{E}=2 \pi \rho_0 \int_0^R \mathrm{d} r \Phi(r) \; r^2 =\frac{3Q^2}{20 \pi \epsilon_0 r}.[/tex]
In your solution, obviously a factor of [itex]4 \pi[/itex] is missing.
Sure, that were typos in the 1st and 3rd equation (I hate the SI because of this damn [itex]\epsilon_0[/itex]...). The rest is fine. I'll correct it also in the original posting.
No worries - there is a thread in PF someplace about the why's and why-nots of that [itex]\epsilon_0[/itex] but if you trained in SI the pain is the other way around.
At first I thought maybe the typo would affect the calculation but I was the epsilon vanished at the spherical coordinates but was recovered in the correct place on the next line. I was concerned this may puzzle someone.
I think we need to hear from Gavroy about the source of his equation.
you are totally correct, i accidentally lost 4 in the denominator. thank you for your help!
  • · Replies 29 ·
