Register to reply
Ideal gas - monatomic or diatomic?
by shyguy79
Tags: diatomic, ideal, monatomic
Share this thread:
shyguy79
#1
Jan15-12, 02:16 PM
P: 102
5 moles of an idea gas at 300K at a pressure of 1.00 x 10^5 Pa is heated to 500K at constant pressure. The amount of heat transferred is 29.1kJ.
Determine whether a gas is monatomic or diatomic through consideration of the values of the molar heat capacity at constant pressure C sub c,m and at C sub v,m
2. Relevant equations
PV = nRT
C = dQ/dT
Cp = Cv + nR
Cv = f/2 nR where f = 3 for monatomic gas and f = 5 for diatomic gas
3. The attempt at a solution
No idea where to start... help please!
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
I like Serena
#2
Jan15-12, 03:09 PM
HW Helper
I like Serena's Avatar
P: 6,188
Quote Quote by shyguy79 View Post
PV = nRT
C = dQ/dT
Cp = Cv + nR
Hi shyguy79!
In a constant pressure process you have Cp=dQ/dT.
Can you calculate Cp from that?
What would you get if you divide Cp by nR?
shyguy79
#3
Jan15-12, 03:16 PM
P: 102
Where dQ = 29.1x10^3 and dT = 200K then Cp = 145.5 J K^-1
Is nR = 5 x 8.314 = 41.57 ???? but why would you do this?
so Cp/nr = 3.5 ???? How does this relate?
I like Serena
#4
Jan15-12, 03:19 PM
HW Helper
P: 6,188
Yep. That is correct.
What would Cp/nR be for a monatomic gas?
And for a diatomic gas?
shyguy79
#5
Jan15-12, 03:37 PM
P: 102
Cp = (f/2 +1) nR so then Cp/nR = (f/2 +1)
so for a monatomic gas... 3/2 + 1 = 2.5
for a diatomic gas... 5/2 +1 = 3.5
so the gas is diatomic?
I like Serena
#6
Jan15-12, 03:39 PM
HW Helper
P: 6,188
Right. :)
shyguy79
#7
Jan15-12, 03:40 PM
P: 102
Thank you so much! I've been stuck on this for ages!
shyguy79
#8
Jan15-12, 04:04 PM
P: 102
Just one question though what equation would be referenced for dividing Cp by nR?
I like Serena
#9
Jan15-12, 04:11 PM
HW Helper
P: 6,188
Not sure what you mean...?
You've used 3 of your relevant equations and solved for "f".
shyguy79
#10
Jan15-12, 04:12 PM
P: 102
doh! Yeah, just noticed - thanks again!
Register to reply
Related Discussions
Ideal monatomic gas cycle Introductory Physics Homework 2
Compression of monatomic ideal gas Introductory Physics Homework 8
Particles in an ideal monatomic gas Advanced Physics Homework 3
Monatomic and diatomic mix Introductory Physics Homework 2
PV diagram of a monatomic ideal gas Introductory Physics Homework 1
