Power Dissipated by a Lightbulb
The power dissipated by a light bulb during a brownout can be calculated using the formula P = V^2/R, where P is the power, V is the line voltage, and R is the resistance. When the line voltage decreases by 10% during a brownout, the power drawn by a light bulb that normally consumes 100.0 W is reduced. By substituting the adjusted voltage (90% of the original) into the equation, the new power can be determined without needing to know the resistance, as it remains constant. The relationship shows that power is proportional to the square of the voltage.
  • Understanding of electrical power formulas, specifically P = V^2/R
  • Knowledge of the concept of voltage and its impact on power consumption
  • Familiarity with the effects of voltage reduction on electrical devices
  • Basic grasp of proportional relationships in physics
  • Calculate power dissipation for various resistance values using P = V^2/R
  • Explore the effects of voltage fluctuations on different types of electrical appliances
  • Study the implications of brownouts on energy efficiency and consumption
  • Learn about electrical safety measures during voltage drops and brownouts
Electrical engineers, physics students, and anyone interested in understanding the impact of voltage changes on power consumption in electrical devices.
Sir Isaac
1. The electric power P is dissipated by a light bulb of resistance R is P=v^2/R, where V represents the line voltage. During a brownout, the line voltage is 10.0% less than its normal value. How much power is drawn by a light bulb during the brownout if it normally draws 100.0 W (watts)? Assume that the resistance does not change.
2. P = V^2/R
3. Since resistance does not change, I disregarded it completely. I then took 100 in place for P and solved for V in the equation. Then I took 10 (my solution to the first problem) in place of V and subtracted 10.0% to find the power that is drawn by the lightbulb during the brownout. But my answer does not match up to the books.
I think you use the 100 watts as P and 120v as v to get the R. Then use the v x.9 and R to get the brownout wattage.
you do not need to know R because it does not change.
The power is proportional to V^2
If V is only 90% 0f the original then the power will be proportional to (0.9)^2 x original V
