Choosing the Correct Term for Measuring Energy Generation in MW h
  • Thread starter Thread starter Jack8rkin
    Term
The discussion revolves around the appropriate terminology for measuring energy generation in megawatt-hours (MW h) within the context of nuclear reactors. Participants explore various terms and concepts related to energy generation, particularly focusing on how to accurately describe the energy produced over the reactor core's operational cycle.
  • One participant seeks clarification on the correct term for energy measured in MW h, suggesting "energy generation" may not be appropriate.
  • Another participant explains that MW h represents the total electrical energy generated in one hour, providing conversions to joules.
  • Some participants propose terms like "power production" and "burnup," with "burnup" being a specific term used in reactor engineering to describe energy per unit mass of uranium.
  • There is a suggestion to use "thermal generation" to emphasize energy rather than nuclear specifics.
  • One participant notes that there may not be a specific English term for the thermal energy generated by the core over one cycle, suggesting "the thermal energy generated over the cycle" as a possible description.
  • Concerns are raised about the potential confusion between different terms and units, such as MW th for thermal power and MWe for electrical output.
  • A participant mentions that "Generated Energy" could be a suitable term, aligning with the Russian translation, but expresses uncertainty about the type of energy being referred to.
  • Another participant shares their experience with calculating thermal energy and electrical energy, discussing the concept of "Heat Rate" as a measure of efficiency.
Participants express differing views on the appropriate terminology and whether specific terms like "burnup" or "energy generation" are suitable. The discussion remains unresolved, with no consensus on a single term being agreed upon.
There are limitations regarding the clarity of terms used in different engineering contexts, and the discussion highlights the potential for confusion between thermal and electrical energy measurements. The appropriateness of terms may depend on the audience and specific applications within nuclear engineering.
Jack8rkin
Hello everyone!
Could you please help me with choosing the correct term?
The situation is as follows:
A reactor generates energy throughtout the core life and it is measured in MW h.
What would you call this characteristic that is measured in MW h?
If translated from Russian (I'm from Russia) word by word it may sound as:
Energy generation
I guess it's not a proper term for that?
Help me please.
Thank you
jedishrfu said:
electrical energy per time = electric power
http://en.wikipedia.org/wiki/Wattage
here's something on the kilowatt-hour:
http://en.wikipedia.org/wiki/Kilowatt_hour
so an MW hour is basically an amount electrical energy generated in one hour
where 100 watts hr = 3.6 megajoules in one hour
so 1KW hour = 36 megajoules in one hour
and 1 MW hr = 36 gigajoules in one hour, I think.
Thank you.
I've already looked through the Wiki, it just explains what is kW h.
I rather need the name of the characteristic measured in kW h that relates to the energy generated over the reactor core life (or a cycle). It describes the amount of energy generated over the period of time between the two fuel reshufflings (reloadings).
I don't believe it is necessarily electric power.
What I'm asking about is... Here is an example:
The characteristic measured in seconds is time.
The characterisitic measured in degrees celsius is temperature.
The characteristic measured in km/h is speed.
What is the characteristic measured in kW h (keeping in mind that it relates to the amount of energy generated over the core life)?
not quite sure who's your audience..
power production comes to mind, though it sounds not rigorously correct, does it..?
the numbers get mighty big.
reactor engineers use unit of megawatt-days, MWD, and call it 'burnup'
or megaqatt-days per metric ton of uranium, MWD/MTU , still called burnup.
they are more interested in the core's nuclide inventory than in resale of energy
and burnup is convenient for tracking that.
plant engineers are more interested in how much electrical energy was produced and sold,
and that we called 'generation',
'gross generation' is what the turbo-generator produced
and 'net generation' is what went out to grid after subtracting our in-house consumption.
Thank you very much!
In fact I'm working for a nuclear engineering company. The term "burnup" is used very often here and it's usualy measured in MW day/t U as you mentioned.
I do not know why, but our guys additionally use the term that, if directly translated from Russian, sounds like "power production" or "energy generation".
One of the guys suggested "energy-producing" that he found in a certain dictionary, but I feel it sounds pretty awkward...
I was also explained that the term in question is the amount of energy produced over a cycle (the time that one core is in operation until the next reloading). The units of measurement that are used for the above magnitude is MW h (which looks pretty similar to MWD).
The situation is that both burnup and "power production" could be used in a table with characteristcs and they need to be differentiated somehow.
My view here is that it does not look approprate if "burnup" is used two times in the same table, or in a paper, even with different units of measurements.
It may cause a lot of confusion.
Thank you again for the response and wonderful clarification.
you're speaking aboout total heat produced by the reactor over a cycle ?
that's a lot of megawatt hours . our reactor was over 2 gw.
if your audience is mechanical engineers why not call it Q[itex]_{total}[/itex] or [itex]\Sigma[/itex]Q or ∫power ?
make units BTU's and really confuse things..
aha - i think we would have called that "thermal generation" (or something similar) for purpose of drawing listener's mind toward energy and away from nucleonics.
The characteristic measured in kw-hr is 'energy.' Other units for energy include joule, BTU, calorie, erg, horsepower-hour, electron volt, Newton meter, and foot-pound.
I don't think there is an english term for the thermal energy generated by the core over one cycle. We might just call it "the thermal energy generated over the cycle." Burnup is a term reserved for discussions of how much of the uranium has been used. It is related to your question but it is different since it is (always) the energy generated per unit mass of uranium (typically MW-days per ton of uranium). In other words, a 'specific energy generation.'
This is wrong or at least it is apt to be confusing. A MW-hr is the energy it takes to generate one MW for one hour. Not in one hour. Watt is a unit of power, it already has the time term in the denominator.
Also, MW-hr is not necessarily reserved for electrical energy. To help keep things straight, core power is typically noted as MWth (where the 'th' signifies 'thermal') and generator electrical output is noted as MWe (where 'e' signifies 'electric').
Thanks to everyone!
Out of what I have read above, I guess that it would be proper to use:
Generated Energy
The units of measurement are appropriate and it is in good correlation with the Russian term.
So what do you say? Will it sound ok in the context?
I'm not sure of what type of energy our guys are speaking here.
I can only assume it is thermal energy, but I'm not sure.
Thanks again
That's what I said to the engineer that asked me about this term!
that sounds okay.
here's a little more background from a plant guy's perspective:
we calculated thermal energy produced every minute
and measured electrical energy going out
kept hourly and daily running totals
divided the two
to get "Heat Rate"
which is just efficiency
we used units of BTU/KWH but you guys are doubtless SI over there.
we did not track long term
just an hourly and a daily heat rate.
point being numerator is heat and denominator is KWH both accumulated over same interval
10,800 was our approximate heat rate
adjacent fossil units would do 9,000 on oil
i'm told combined cycle units can beat 6,000
heat-rate was the number of interest to our financial types.
i'm not sure of what use total heat procuced in a cycle would be
but you can't average rates,
so if you want a number for the whole year's heat rate you have to accumulate heat and kwh separately and divide them.
they'll be huge numbers so have your programmers check to make sure you won't overflow your spreadsheet's math algorithms - some I've heard only go to 10^35.
probably that's enough though. just that ounce of prevention
if that's what you are doing with the number , maybe a label or subscript like 'accumulated cycle (heat, Q, gigaloules - pick a mnemonic noun)' ?
you know your audience and i dont. can you ask one of them via a backdoor?
good for you for so much effort in choosing a name. Lavoisier wrote at length in his introduction to treatise on chemistry about importance of naming terms. google his name and 'lemoyne.edu'
I just looked through the papers and it turns out to be that the guys use QT to denote the energy generated by the certain moment of the cycle (they measure it in GW h). It relates to cacluations of burnup distribution.
My audience is the guys who develop computer codes.
  • · Replies 78 ·
  • · Replies 35 ·
  • Poll Poll
  • · Replies 16 ·
12K
