Graphite and it's application in batteries.
Graphite is a highly effective electrode material for batteries, boasting a theoretical specific capacity of 372mAh/g, which significantly surpasses that of most other materials. This capacity, measured in milli-Ampere hours per gram (mAh/g), indicates the charge storage capability of graphite. Additionally, the lithium-graphite matrix exhibits a stable state-of-charge versus potential profile, independent of the lithium-to-carbon stoichiometric ratio. The reversible intercalation and deintercalation of lithium ions in graphite further enhance its suitability for rechargeable battery applications.
  • Understanding of battery chemistry and electrochemistry
  • Familiarity with specific capacity measurements in mAh/g
  • Knowledge of intercalation and deintercalation processes
  • Basic concepts of lithium-ion battery operation
  • Research the electrochemical properties of graphite in lithium-ion batteries
  • Learn about the intercalation and deintercalation mechanisms in battery materials
  • Explore the impact of stoichiometric ratios on battery performance
  • Investigate alternative electrode materials and their specific capacities
Researchers, battery engineers, and materials scientists interested in the development and optimization of lithium-ion battery technologies.
Padford
A little coursework question.
In one of my sources, of research it says that "Graphite has a theoretical specific capacity of 372mAh/g, much higher than most other electrode materials that have proven their worth in the battery industry." I'm not sure if mAh/g is a measure of current vs. voltage. If it is relevant to the physics of my title (Graphite and it's application in batteries) then could you please explain what it is! thank you.
Also, the same source goes on to say "It’s [graphite's] state-of-charge vs. potential profile is desirable, as the potential of the lithium graphite matrix does not depend strongly on the stoichiometric ratio of lithium to carbon," I think this may be verging on the chemistry side of things - in the way that the stoichiometric ratio is basically the mole ratio, but do you think I should mention it briefly, or not?
Lastly, The source then goes on to say, " Intercalation and deintercalation of lithium in graphite are highly reversible, making the material quite suitable for rechargeable batteries." I think this would be very useful, if I knew what intercalculation and deintercalculation are, could you explain they are?
Thanks in advance and Merry Christmas!
Padford.
mAh/g is milli-Ampere . hours per gram. It's used to measure charge capacity.
Thanks
Graphite has a theoretical specific capacity of 372mAh/g, but i don't understand why that makes it a good electrode?
  • · Replies 18 ·
  • · Replies 25 ·
16K
  • · Replies 28 ·
11K
  • · Replies 16 ·
