Splitting fractional expression into real/imaginary parts
The discussion revolves around splitting a fractional expression involving complex numbers into its real and imaginary components. The original poster presents a specific expression related to absorption coefficients and indices of refraction, indicating a context in physics or engineering involving complex analysis.
  • The original poster attempts to manipulate the expression by defining variables for simplification and seeks a method to eliminate the imaginary unit from the denominator. Some participants suggest using the complex conjugate to achieve a real denominator, while others reiterate this approach with additional clarification.
Participants are actively discussing methods to manipulate the expression, with some guidance provided on using the complex conjugate to simplify the problem. There is a recognition of the algebraic nature of the issue, and while multiple interpretations of the approach are explored, no explicit consensus has been reached.
The original poster expresses frustration over the complexity of the algebra involved and indicates a desire for clarity in separating the real and imaginary parts. The discussion reflects a common challenge in handling complex fractions in mathematical contexts.
Millertron
Hi guys, I'm having a bit of trouble splitting the RHS of the following expression into real and imaginary parts:
[itex](χ'+iχ")/A = \frac{1}{ω-ω_{0}-iγ/2}[/itex]
(It's to find expressions for absorption coefficient and index of refraction, but that's irrelevant).
I've defined a = [itex]ω-ω_{0}[/itex] and b = γ/2 for simplicity, and am looking for the form given by Wolfram under 'Alternate form assuming a and b are real', as this has a clear real and imaginary part. So far I've got to
[itex]= \frac{1}{a-ib}[/itex]
[itex]= \frac{a-ib}{(a-ib)^{2}}[/itex]
[itex]= \frac{a}{(a-ib)^{2}}[/itex] - [itex]\frac{ib}{(a-ib)^{2}}[/itex]
only when I expand the squared brackets in each denominator I get [itex](a-ib)^{2}=a^{2}-b^{2}-2iab[/itex], which is no good as I need to remove the i's in the denominator.
I know it boils down to a simple algebra/complex nos question but I've been working on this problem for so long that my brain is ceasing to function. Any help is much appreciated!
the trick is to multiply by the complex conjugate to get a real denominator
[tex]\frac{1}{a-ib}= \frac{1}{a-ib}\frac{a+ib}{a+ib}= <br /> \frac{a+ib}{a^2+b^2}[/tex]
[itex]\displaystyle=\frac{a}{a^2+b^2}+\frac{b}{a^2+b^2}i[/itex]
Of course! Definitely should've known this, thanks a lot guys!
no worries, one way to remember is that mulipllying by a complex congujate gives a you a magnitude, which is always real
  • · Replies 19 ·
  • · Replies 18 ·
