Proving 0 < θ1 < β in θ12-γθ1+β=0
  • Thread starter Thread starter Kinetica
The discussion revolves around the quadratic equation θ12 - γθ1 + β = 0, with the goal of demonstrating that 0 < θ1 < β. Participants are exploring the implications of this equation in the context of the parameters involved, particularly focusing on the values of θ1, γ, and β.
  • Some participants attempt to evaluate the quadratic equation at specific values of θ1, questioning how these evaluations can lead to the desired inequalities. Others raise concerns about the lack of information regarding the parameters β and γ, suggesting that their values significantly affect the conclusions that can be drawn.
The discussion is ongoing, with participants providing insights and questioning the assumptions made about the parameters. There is recognition that more information is needed regarding the values of β and γ to substantiate the inequalities involving θ1.
Participants note that the values of β and γ are not clearly defined, which complicates the ability to assert the inequalities required. There is also mention of potential values for β, including the possibility of it being zero or negative, which could impact the conclusions drawn about θ1.
Kinetica
θ12-γθ1+β=0
Show that
0<θ1
I know that for θ1=0, θ12-γθ1+β>0:
Substituting, we get 02-0+β=β, which is positive.
I don't know how to show that for θ1=λ, θ12-γθ1+β<0.
I also don't know how to show that these results imply that there is zero between these two values. Which in turns means that 0<θ1<β.
Well, θ12-γθ1+β=0 is just a quadratic equation in θ1, so there should be at most two possible values for θ1, in terms of the other parameters.
[tex]\theta_{1} = \frac{\gamma\pm\sqrt{\gamma^{2}-4\beta}}{2}[/tex]
But as things stand, you haven't given nearly enough information to assert the inequalities required. For example, why shouldn't β be zero or even negative? Is γ greater than zero, greater than one?
consider for instance β=0 and y=θ then θ can be whatever you like as long as y is also!
OK so I found this on your other request, and it looks like it could apply here.
Kinetica said:
θ12
θ12
but that just means that the relative sizes of θ1 and β depend on θ2. So still no closer to that inequality - there's something you aren't telling us about this question...
Kinetica said:
θ12-γθ1+β=0
Show that
0<θ1
This thread is very similar in topic to a thread you started one day earlier: https://www.physicsforums.com/showthread.php?p=3717073#post3717073 .
Where did λ (lambda) come from, or should that be γ (gamma) ?
I suppose we can infer that β > 0 from the inequality, 0<θ1<β, and because you mentioned it in passing, "Substituting, we get 02-0+β=β, which is positive."
It makes no sense to plug values such as 0 or γ or λ in for θ1 in the quadratic polynomial θ12-γθ1+β to see if 0<θ1<β .
As Joffan said, you need more information regarding β and γ, before you can say much about θ1 .
