Verifying Conservation of Energy for Vertical Spring Oscillator
  • Thread starter Thread starter Soaring Crane
    Oscillator Vertical
The discussion confirms that the conservation of energy holds for a vertical spring oscillator where the displacement is measured from the vertical equilibrium position (x_0 = mg/k). The total energy (E) is expressed as the sum of kinetic energy (KE) and potential energies (PE_grav and PE_spring). The calculations demonstrate that E_x0 equals E, validating that total energy remains constant throughout the oscillation, a fundamental principle in physics essential for understanding vertical spring oscillators.
  • Understanding of Newton's laws of motion
  • Familiarity with potential and kinetic energy concepts
  • Knowledge of spring force and Hooke's Law
  • Basic algebra for manipulating equations
  • Learn how to derive the equations of motion for a vertical spring oscillator
  • Study the implications of energy conservation in oscillatory systems
  • Explore the concept of damping in spring oscillators
  • Investigate the effects of varying mass and spring constants on oscillation behavior
Students of physics, educators teaching mechanics, and engineers working with oscillatory systems will benefit from this discussion on energy conservation in vertical spring oscillators.
Soaring Crane
Show that the conservation of energy holds also for the vertical spring where x is measured from the vertical equilibrium position (x_0 = mg/k) for a mass m.
This is what I did so far. Where do I go from here?
f = mg - kx_0 = 0
kx_0 = mg
E = KE + PE_grav + PE_spring
= ([mv^2]/2) - mg(x + x_0) + [(x + x_0)^2]/2
= ([mv^2]/2) - mgx - mgx_0 + (k/2)[x^2 + 2xx_0 + x_0^2]
= ([mv^2]/2) - mgx - mgx_0 + [(kx^2)/2] + xx_0k + [(kx_0^2)/(2)]
E_x0 = ([mv^2]/2) - mgx_0 + [(kx_0^2)/2]
Thanks for helping.
Consider finding an expression for your velocity in terms of the position. Then compare energy at the equilibrium postion to that at maximum extension.
Also please consider reading through this thread to learn how to present equations in a more readable format.
To continue, you can substitute mg/k for x_0 in the equation for E_x0 to get:
E_x0 = ([mv^2]/2) - mg(mg/k) + [(k(mg/k)^2)/2]
= ([mv^2]/2) - (mg^2)/k + (mg^2)/(2k)
= ([mv^2]/2) - (mg^2)/(2k) + (mg^2)/(2k)
= ([mv^2]/2)
Since this is the same as the equation for E, we can conclude that E_x0 = E, showing that the conservation of energy holds for the vertical spring oscillator. This means that the total energy (kinetic energy + potential energy) remains constant throughout the oscillation, regardless of the position of the mass. This is a fundamental principle of physics and is a crucial concept in understanding the behavior of systems such as the vertical spring oscillator.
  • · Replies 22 ·
