Radiation How radiation affects different configurations of a clothes horse
  • Context: Undergrad
  • Thread starter Thread starter gwood311
    Radiation
The discussion revolves around the effects of different configurations of a clothes horse on the drying efficiency of clothes when placed near a radiator. Participants explore the scientific principles behind heat transfer, humidity, and air circulation, and how these factors influence drying times in various orientations of the clothes horse.
  • One participant describes two configurations: placing the clothes horse perpendicular to the radiator versus parallel, seeking to determine which would dry clothes faster.
  • Another participant suggests an unconventional method of hanging clothes to maximize drying efficiency, although they express uncertainty about the concept of a clothes horse.
  • A third participant explains that radiators primarily heat by convection rather than radiation, discussing how relative humidity affects drying rates and the importance of air circulation around the clothes.
  • This participant also notes that with fewer garments, parallel placement may be more effective, but as the number of garments increases, the drying efficiency may not significantly differ between the two orientations.
  • Another point raised is that the radiation from the radiator could be obstructed by the first piece of clothing in a parallel arrangement, potentially affecting drying times.
  • A final participant compares the radiator's function to that of a light bulb, suggesting that maximizing exposure to the "light" (radiant heat) is crucial for effective drying.
Participants express differing views on the effectiveness of the clothes horse's orientation relative to the radiator, with no consensus reached on which configuration is definitively better for drying clothes.
Participants mention factors such as humidity levels, air circulation patterns, and the nature of heat transfer, but do not resolve the complexities of these interactions or provide definitive equations for analysis.
This discussion may be of interest to individuals exploring practical applications of heat transfer principles, those seeking to optimize drying methods in home settings, or anyone curious about the science behind drying clothes efficiently.
gwood311
I have a clothes horse on which clothes can be hung parallel to each other roughly 50 cm apart. I place the clothes horse perpendicular to the radiator so the heat from the radiates along the length of the wet clothes. However my flatmate places the clothes horse parallel to the radiator so the heat must first radiate through one wet garment before getting through to the second garment.
Can anybody help me with a scientific solution to this question. Any equations for working this out would be good but I'm mainly looking for a description as to which drying configuration would dry the clothes the fastest.
Science news on Phys.org
Hang one article of clothing right side up, and another upside down. Then place one inside the other. Keep in mind, I have no idea what a clothes horse is... but the general idea is to make two articles of clothing dry as though they were more or less one. Drying the Front side of one shirt and the back side of the other in roughly equal time.
Clothes horse - much better name than a clothes drying rack - I like.
I imagine you are talking about a baseboard heater or radiator, which actually in operation heat a room by convection and very little by means of radiation.
What happens is as follows:
- the air in your room has a certain humidity level, which means the amount of moisture in the air
- 100% relative humidity means that the air is completely saturated with moisture and can hold no more. If your room is 40% relative humidity, clothing will still dry.
- and as the air warmed by the radiator is able to hold more moisture - the relative humidity of the warmed air has fallen to a lower level.
- the warmer air, now a little "dryer" can accept moisture from your clothes a little more quickly
- the warmer air rises, accepts moisture, becomes a little more humid, and is continiously replaced by more "dryer" warm air that passes around the clothing.
So the question of whether the orientation of parrallel or perpindicular placement of the clothes horse to the radiator will dry clothes the fastest, is subject to the air circulation pattern set up around the clothes. If one is drying one or two pieces of clothing, then parrallel would be the best as both pieces of clothing are above the radiator. As the number of pieces of clothing increases, more garments ( or parts of the garment ) will be farther from the radiator and not dry as quickly, so I suspect placement, parrallel or perpendicular, would not matter, all things being equal,
On the other hand, the small amount of radiation transmiitted from the radiator to the clothing, would be blocked by parallel placement of the first piece of clothing.
You could test orientation and clothing drying times by timing "test runs" of each orientation and note the length of time it took to when you feel the clothing is dry.
If you are using radiant heat then think of the radiator as a big light bulb. Then position the clothes so that as much of the "light" from the light bulb is blocked, as though you were trying to dim the room.
  • · Replies 32 ·
  • · Replies 94 ·
15K
