Understanding a Rotation Problem: Mass, Length, and Acceleration Calculations
  • Thread starter Thread starter Silimay
    Rotation
The discussion centers on the calculations involved in analyzing the motion of a uniform rod of mass M and length l, supported at one end and connected to a ceiling by a thread. Key calculations include determining the force exerted on the rod by the axis, the angular acceleration α, translational acceleration a, and angular velocity ω as a function of the angle θ. The moment of inertia is established as I = M*l^2/3, and the correct expressions for angular acceleration and translational acceleration are derived as α = 3/2(g/l) and a = 3g/2, respectively. The conservation of energy approach is critiqued for inaccuracies in calculating gravitational potential energy.
  • Understanding of rotational dynamics and torque calculations
  • Familiarity with moment of inertia concepts
  • Knowledge of angular and translational acceleration relationships
  • Basic principles of conservation of energy in physics
  • Study the derivation of torque and its applications in rotational motion
  • Explore advanced topics in rotational dynamics, including angular momentum
  • Learn about the conservation of energy in mechanical systems
  • Investigate the effects of forces on rigid body motion
Physics students, educators, and anyone interested in understanding the mechanics of rotational motion and the dynamics of rigid bodies.
Silimay
I have tried this problem, but there are parts of it I don't understand, and I'm not sure that I've done it all correctly.
A long, uniform rod of mass M and length l is supported at the left end by a horizontal axis into the page and perpendicular to the rod, as shown above. The right end is connected to the celing by a thin vertical thread so that the rod is horizontal. The moment of inertia of the rod about the axis at the end of the rod is M*l^2/3. Express the answers to all parts of this question in terms of M, l, and g.
Rod:
______________Rod_________________|
x---------------------------------------|
x = axis of rotation
Right side = thread
Thread is attached to wall (above and parallel to rod)
I don't know if you can understand the picture or not...hopefully you can.
a. Determine the magnitude and direction of the force exerted on the rod by the axis.
The force of gravity = Mg and acts upon the rod at its center of mass (correct me if I'm wrong). So should the force exerted on the rod by the axis by Mg/2?
The thread is then burned by a match. For the time immediately after the thread breaks, determine each of the following.
b. The angular acceleration α of the rod about the axis.
Torque = I*α = F x r
I = M*l^2/3
Torque = M*l^2/3*α = Mgl/2
α = 3Mgl/(2Ml^2) = 3/2(g/l)
c. The translational acceleration a of the rod about the axis.
a = αr = 3/2(g/l)*l = 3g/2
d. The force exerted on the end of the rod by the axis.
I had no clue how to do this one.
The rod rotates about the axis and swings down from the horizontal position.
e. Determine the angular velocity of the rod as a function of θ, the angle through which the rod has swung.
I used conservation of energy:
Initial potential energy (+ 0 K) = Final kinetic energy (+ 0 U)
l/2*(1-sin(θ))gM = 1/2(I)(ω)^2 = 1/6(M*l^2*ω^2)
That gives me:
ω = [(3(1-sin θ)g)/(l)]^(1/2)
Is that correct?
Any help is very much appreciated in advance! :-)
Think of it as the force that is responsible for the centripetal acceleration.
The rest from a to c looks good to me (I haven't checked e) except maybe a sign in your torque.
Your solutions for a, b, and c are correct.
In part c you found the translational acceleration. Now figure out what force the axis must exert on the rod to produce that acceleration.
That gives me:
Is that correct?
No. The use of conservation of energy is correct, but you calculated the change in gravitational PE incorrectly.
  • · Replies 17 ·
