Difference of two square integers
The discussion revolves around identifying the 2002nd positive integer that cannot be expressed as the difference of two square integers. Participants explore various approaches and reasoning related to the properties of such integers, including their classifications and the conditions under which they can be represented as differences of squares.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • Some participants propose that the integers which cannot be expressed as the difference of two squares include all even numbers greater than or equal to 4 and all odd numbers greater than or equal to 3.
  • One participant suggests that the perfect differences are all odd numbers (>=3) and all multiples of 4 (>=8), while also noting that certain numbers are repeated in the differences.
  • Another participant challenges the assertion that there are only two integers that cannot be expressed as such, arguing that there is a misunderstanding regarding the counting of these integers.
  • There is a discussion about the mathematical proof involving the expressions for even and odd integers and their relationship to being a difference of squares.
  • Some participants express uncertainty about the validity of their calculations and the implications of including certain integers like 1 and 4 in their counts.
  • A later reply questions whether every integer divisible by 4 is indeed a difference of squares, indicating a potential gap in the earlier reasoning.
Participants do not reach a consensus on the exact integers that cannot be expressed as the difference of two squares. There are competing views on the classification of these integers and the correctness of the proposed solutions.
Some participants note limitations in their assumptions about the positivity of integers involved in the differences, and there are unresolved mathematical steps regarding the proof of certain integers being differences of squares.
Readers interested in number theory, particularly in the properties of integers related to squares and their differences, may find this discussion relevant.
primarygun
Find the 2002nd positive integer that is not the difference of two square integers.
I have idea for the answers, but there are two.
Mathematics news on Phys.org
How about posting your ideas?
well, that would mean that the integer cannot be a^2 - b^2, if a > b... i vaguely remember doing this before, but all i can remember is that it really comes down to finding what numbers *cant* be expressed as the difference of two squares, and then sort of just doing it... sorry I am not very helpful
Thank you. That helps me a lot !
Hello, primarygun
There are two?
I can't understand how could that be.
If we put all these numbers in a series, just one is in the place 2002! :confused:
Anyway...
x=a^2-b^2
I SUPPOSE THAT a,b>0
If a number can be written as a difference of two perfect squares then I'll call that number a perfect difference
Well, that's what I found
First, I wrote down some squares, from 1^2 to 10^2 and I found the differences (you can easy do it on Excel)
I noticed that the differences are either
3,5,7,9,11,..
or
8,12,16,20,24,..
And there is not other!
(But there are numbers which are repeated many times, e.g
24=7^2-5^2, but also
24=5^2-1^2)
That is, the perfect differences are all even numbers (>=3) and all multiples of 4 (>=8)
I think that I must prove it :rolleyes:
Well, say x=a^2-b^2 => x=(a+b)(a-b)
(That is we suppose that x is a perfect difference)
Of course a>b
x may be either odd or even
1)
x is even
so x=2q (where q>=1)
(a-b)(a+b)=2q
The second side is even
So a-b is even or a+b is even
but if a-b is even then a+b is even too:
a-b=2k =>
a=b+2k =>
a+b= (b+2k)+b = 2b+2k = 2(b+k)
Then x = 2k*2(b+k) = 4k(b+k)
Since k>=1 & b>=1 the value of k(b+k) has a minimum value 1*(1+1)=1*2=2
So, IF x is even THEN x=4r, where r>=2
(That is, all multiples of 4, except 4)
2)
x is odd
so x=2k+1
but if you set
a=k+1
b=k
then you get a^2-b^2 = (a-b)(a+b) = 1*(k+k+1) = 2k+1
Since b>=1 => k>=1 => x>2*1+1 =>
x>=3
So, IF x is odd & x>=3 THEN x is a perfect difference.
We found that the perfect differences are:
-the odd numbers (>=3)
-the multiples of 4 (>=8)
In other words if x=4k+m (you divide by 4, k is the quotient and m is the remainder)
m=0 => x is a perfect difference
m=1 => x is a perfect difference (because x is odd)
m=3 => x is a perfect difference (because x is odd)
But if m=2 <=> x=4m+2 <=> x=2(2m+1)
then x isn't divisible by 4, so x is NOT a perfect difference
The desired numbers are all the doubles of an odd, x=2(2m+1)
and also, x=4 and x=1
(x=4 is the only multiple of 4 which is less than 8
x=1 is the only odd number <3)
So, can you now find which NON perfect difference is at the place 2002?
If you don't understand something, just tell me, ok?
Thanks.
Actually, I have already got the solution. But I suspect the answer from that book.
Doesn't matter !
It was actually a very good problem, so I was glad to deal with this! :smile:
8006?......
I think you forgot to count x=4 and x=1
Put all even numbers in a series
The first one is 1
The next 3,5,7,...
The 2002nd is 4003 (if I calculated right)
Double them
The first is 2, then 6,10,14,...
The 2002nd is 8006
But there are also the numbers x=4 and x=1
There are 2 numbers, so we want the 2000th in the series 2,6,10,14,..., which is 7998
(n=2000=>
k=2n-1= 3999 =>
2k = 7998)
Popey, 4 and 1 are a difference of square integers. 1=1^2-0^2 and 4^2-0^2. Zero is a square integer.
Also, while your proof shows that if a positive integer divisible by 2 is a difference of squares then it's divisible by 4, you did not show that every integer divisible by 4 is a difference of squares. Did you deal with this primarygun?
Thanks, shmoe!
Anyway...
x=a^2-b^2
Since I didn't knew for a and b, if they are positive, I supposed that they are!
That's why I reject the values
x=1=12-02
x=4=42-02
With this shmoe's comment , primarygun is correct! the number is 8006
About your second comment, I did it to my paper but I didn't post it here, because I thought that it's not important.
Now I see clearly that it's important! :frown:
Well, suppose that x=4n (n>0 because x>0)
x=2*2n
if you set a=n+1 & b=n-1, then
a2-b2=
(a+b)(a-b)=
[(n+1)-(n-1)][(n+1)+(n-1)]=2*2n=x
Thank you!
were trying to count out the occurrence of the sum of consecutive odd positive integers.
  • · Replies 23 ·
  • · Replies 31 ·
