Mathematica: Infinite expression error when using NDSolve
The forum discussion centers on an issue encountered while using Mathematica's NDSolve function to solve a nonlinear ordinary differential equation (ODE). The user attempts to solve the equation with initial conditions f(1) = 0 and f(-1) = 0 but receives an "Infinite expression 1/0" error. The suggested approach includes using the Trace function to diagnose the problem, which indicates that NDSolve is employing the shooting method. The user is advised to contact Wolfram Research, Inc. (WRI) tech support for further assistance.
  • Familiarity with nonlinear ordinary differential equations (ODEs)
  • Understanding of Mathematica's NDSolve function
  • Basic knowledge of initial conditions in differential equations
  • Experience using Mathematica's Trace function for debugging
  • Explore advanced features of Mathematica's NDSolve function
  • Learn about the shooting method for solving boundary value problems
  • Investigate common error messages in Mathematica and their solutions
  • Contact Wolfram Research, Inc. tech support for specific Mathematica issues
Mathematica users, mathematicians, and engineers working with differential equations who need to troubleshoot NDSolve errors.
stephanie22
Dear all,
If someone could help me solve this mathematica NDSolve problem, that would be really nice. Here is a related, simpler problem to the one I am having. Suppose I want to solve the nonlinear ODE
[tex] \left(2 r + f(r) f'(r) \right) (1 + f'(r)^2) + r f(r) f''(r) = 0 [/tex]
subject to the initial conditions
[tex] f(R) = f(-R) = 0 \,.[/tex]
This problem is simpler than the one I actually want to solve, because in this case I know that the solution is
[tex] f(r) = (R^2 - r^2)^{1/2} \,. [/tex]
I would like to try and recreate the above solution by using NDSolve in mathematica. I try using the code
Code:
NDSolve[{(2 r + f[r] f'[r]) (1 + f'[r]^2) + r f[r] f''[r] == 0,
  f[1] == 0, f[-1] == 0}, f, {r, -1, 1}]
but I receive the error message "Power::infy: Infinite expression 1/0. encountered." I would like to recreate the solution f(r) = \sqrt{1 - r^2}.
Thanks in advance for any help!
Steph
An interesting question (and well asked). Unfortunately, I don't have a good answer for you.
If you use Trace[ NDSolve[...], TraceInternals->True], then you can see that NDSolve is trying the shooting method when it all goes wrong. However, I'm not sure what exactly is going wrong nor how to fix it.
I suggest you contact WRI tech support (http://www.wolfram.com/support/contact/) and see if they can sort it out.
If they do have a good answer, it would be great if you could post it here.
  • · Replies 19 ·
  • · Replies 0 ·
