Register to reply
Increased voltage increases or decreases current?
by tpodany88
Tags: current, decreases, increased, increases, voltage
Share this thread:
tpodany88
#1
Jan21-12, 05:39 PM
P: 7
I am a little confused on how an increase in voltage would increase current.
If i have a 1000w fixture with 120vac supplied the current will be 8.333amps
After increasing the voltage to 240vac, the same 1000w fixture would draw 4.16 amps.
Please help me understand what I am missing here.
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
Pengwuino
#2
Jan21-12, 05:49 PM
PF Gold
Pengwuino's Avatar
P: 7,120
Well, tell us what you think should happen.
phinds
#3
Jan21-12, 05:56 PM
PF Gold
phinds's Avatar
P: 6,129
You seem to have a poor understanding of the relationship among impedance, voltage, current, and power. Try looking up the definitions.
tpodany88
#4
Jan21-12, 05:56 PM
P: 7
Exactly what happens in my example. But I have read elsewhere that the current is directly proportional to the increase/ decrease of voltage.
phinds
#5
Jan21-12, 05:58 PM
PF Gold
phinds's Avatar
P: 6,129
Quote Quote by tpodany88 View Post
read more
tpodany88
#6
Jan21-12, 06:01 PM
P: 7
Quote Quote by phinds View Post
read more
Obviously that is what I am doing. A little direction would be helpful.
vk6kro
#7
Jan21-12, 06:03 PM
Sci Advisor
P: 4,016
The lamp will not be the same lamp on 240 volts as you used on 120 volts.
So, if your lamp was 14.4 ohms, the current in it would be 120 volts / 14.4 ohms = 8.33 amps and the power would be 120 volts * 8.3333 amps or 1000 watts, as you said.
But if you now put a different lamp of 57.69 ohms in, and apply 240 volts, the current will be 4.16 amps.
So, the power will be 240 volts * 4.16 amps or 1000 watts.
tpodany88
#8
Jan21-12, 06:10 PM
P: 7
Quote Quote by vk6kro View Post
Thanks! I forgot about the fact the bulb must be replaced... although the ballast remains the same.
tpodany88
#9
Jan21-12, 06:17 PM
P: 7
But now that I realize the bulb doesn't need to be replaced and can run on 120 or 240v.
vk6kro
#10
Jan21-12, 06:38 PM
Sci Advisor
P: 4,016
You didn't say anything about a ballast.
If it was an electronic ballast, you can't really apply Ohm's Law to it. It would just give the lamp the current it requires even if the input voltage changed.
tpodany88
#11
Jan21-12, 06:40 PM
P: 7
Is that the same for a magnetic ballast?
vk6kro
#12
Jan21-12, 06:54 PM
Sci Advisor
P: 4,016
No, I don't think so.
If you tried to use an iron-cored inductor intended for 120 volts, on 240 volts, I expect it would destroy the lamp and possibly itself with the extra current.
It definitely would not supply less current to the lamp at the higher voltage.
tpodany88
#13
Jan21-12, 06:58 PM
P: 7
It is a magnetic ballast that can be used with either 120v or 240v. I don't believe the bulb needs to be changed with a change in supply voltage.
Maybe the best way to figure it out would to just wire it on 120v, check the amp draw.. then change the supply to 240v and check amp draw because I feel like I'm only confusing myself more.
Thanks for your help tho.
Antiphon
#14
Jan21-12, 06:59 PM
P: 1,781
You are exactly correct if the load is constant power. Most modern ballasts will do exactly what you describe.
Zula110100100
#15
Jan22-12, 12:34 AM
P: 253
Some ballasts you have to open and change a wire(I assume it is for the number of turns that are energized?) to 240(208?) from 120...
NascentOxygen
#16
Jan22-12, 05:17 AM
HW Helper
Thanks
P: 5,166
In which case I expect you will find that you need to connect it up differently for the different potentials.
That is sure to give you some answers. Stand well back from it when you apply the 240v.
sophiecentaur
#17
Jan22-12, 06:59 AM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,950
Are you talking about Resistors or Transformers?
Register to reply
Related Discussions
Why thrust decreases then increases with velocity? General Physics 1
Decreaseing voltage increases current Electrical Engineering 10
Entropy-increases & decreases Biology, Chemistry & Other Homework 2
If g decreases as h increases, then why does gravitational potential energy increase? Introductory Physics Homework 5
