What is the Net Electric Field at the Center of a Square with Four Charges?
The net electric field at the center of a square with four charges, where two charges are positive and two are negative, can be calculated using the formula E = k (q / r^2). The distance from the center to each charge is a/(2^1/2). The x-components of the electric field cancel out, leaving only the y-components contributing to the net electric field. The correct constant value for k is 9.0 x 10^9 N m²/C², not 9.0 x 10^10 as initially assumed.
  • Understanding of electric fields and point charges
  • Familiarity with Coulomb's law
  • Basic knowledge of vector components
  • Proficiency in algebra and trigonometry
  • Study the derivation of electric fields from point charges
  • Learn about superposition principle in electric fields
  • Explore the concept of electric field lines and their representation
  • Investigate the effects of charge configuration on electric field strength
Students studying electromagnetism, physics educators, and anyone interested in understanding electric fields generated by multiple point charges.
spiffmonkey1
A point charge is placed at each corner of a square with side length a. The charges all have the same magnitude q. Two of the charges are positive and two are negative, as shown in the following figure.
The two positive charges are on top and the two negative charges are on the bottom
What is the magnitude of the net electric field at the center of the square due to the four charges in terms of q and a?
E = k ( q / r^2), k = 9.0*10^9
The distance from the middle to one of the charges a/(2^1/2)
The x-components cancel out, leaving only the y-components.
The electric field due to one of the charge to my guess is-
E1sinω = 9.0*10^9 ( 2q / a^2 ) * (1/ (2^1/2))
I assumed that each charge exerts the same electric field so the answer would\ be
4 * 9.0*10^9 ( 2q / a^2 ) * (1/ (2^1/2))
I am not sure what I did wrong.
Thanks so much
Nevermind, masteringphysics believes that k != 9.0 * 10^10 , correct answer above
Mod close thread please.
