First order non-separable linear deq's using an integration factor?
The discussion focuses on solving first-order non-separable linear differential equations using an integration factor. The example provided, t(dy/dx) + 2t²y = t², demonstrates the process of multiplying by the integration factor u(x) = e^(∫2t dt) = e^(t²). This method allows the left side of the equation to be expressed as the derivative of a product, facilitating integration. The final solution derived is y = Ce^(-x) + (1/4)e^(3x), confirming the effectiveness of this technique in solving such equations.
  • Understanding of first-order linear differential equations
  • Familiarity with integration factors and the product rule
  • Knowledge of exponential functions and their properties
  • Basic calculus skills, including integration techniques
  • Study the derivation of integration factors in linear differential equations
  • Explore advanced techniques for solving non-separable differential equations
  • Learn about the application of differential equations in real-world scenarios
  • Investigate numerical methods for approximating solutions to complex differential equations
Students and professionals in mathematics, engineering, and physics who are working with differential equations and seeking to enhance their problem-solving skills in this area.
QuarkCharmer
For example:
[tex]\frac{dy}{dx} + y = e^{3x}[/tex]
I understand that these differential equations are most easily solved by multiplying in a factor of integration, and then comparing the equation to the product rule to solve et al..
For example:
[tex]t\frac{dy}{dx} + 2t^{2}y = t^{2}[/tex]
[tex]\frac{dy}{dx} + 2ty = t[/tex]
Multiplying in an integration factor u(x), which in this case:
[tex]u(x) = e^{\int{2t}dt} = e^{t^{2}}[/tex]
[tex]e^{t^{2}}\frac{dy}{dx} + 2te^{t^{2}}y = te^{t^{2}}[/tex]
Now I can compress the left side down using the product rule and all that.
I don't understand how they are getting u(x) or why it's equal to e^{\int{2t}dt} ?
First we multiply the equation with an unkown function u(x)
[tex]u(x)\frac{dy}{dx}+u(x)y=u(x)e^{3x}[/tex]
The goal is to recognize the left side as the derivative of a known function. Because then we can integrate both sides.
Now, remember the product rule
[tex]\frac{d}{dx}(u(x)y)=u(x)\frac{dy}{dt} + \frac{du(x)}{x}y[/tex]
This looks a lot like the left side, doesn't it?? The only thing we want is
[tex]\frac{du(x)}{dx}=u(x)[/tex]
Such a differential equation is easily solved. Indeed, it is clear [itex]u(x)=e^x[/itex] satisfies this.
So now we got
[tex]\frac{d}{dx}{e^x y}=e^{4x}[/tex]
Integrating both sides gives us
[tex]e^x y = \frac{1}{4}e^{4x}+C[/tex]
or
[tex]y=Ce^{-x}+\frac{1}{4}e^{3x}[/tex]
Thanks Micro, this answers my questions perfectly.
  • · Replies 16 ·
