Cohomology with compact support
  • Context: Graduate
  • Thread starter Thread starter Jamma
    Compact Support
The discussion revolves around the concept of cohomology with compact support in the context of Poincare duality, particularly focusing on the implications for singular chains and cochains. Participants explore definitions, properties, and nuances related to compact support in various homological theories.
  • One participant expresses confusion about how the boundary of a singular chain can be a singular chain with compact support, particularly in contrast to simplicial and cellular chains.
  • Another participant suggests that for compactly supported simplicial cohomology to be meaningful, simplices must be locally finite, ensuring the coboundary map is well-defined.
  • A later reply clarifies that in singular cohomology, the coboundary of a compactly supported cochain remains compactly supported due to the properties of the coboundary operator.
  • One participant highlights a specific property of compactly supported k-cochains, noting that if a cochain evaluates to zero outside a compact subset, its coboundary also retains this property.
  • Another participant identifies a subtlety in the definition of compact support, emphasizing that cochains should evaluate to zero on chains outside a compact subset rather than non-zero values inside it.
  • There are recommendations to explore different texts, such as Bott and Tu's work on Poincare duality using differential forms, which presents alternative approaches to the topic.
  • A participant mentions the need for Borel-Moore homology, which accommodates chains of non-compact support, and notes its relation to Poincare duality.
Participants express differing views on the interpretation of compact support in cohomology, with some clarifying definitions while others remain uncertain about the implications. The discussion does not reach a consensus on the nuances of the definitions and their applications.
Participants note the importance of local finiteness in ensuring the well-defined nature of coboundary maps and the subtleties in definitions that affect the understanding of compact support.
Readers interested in algebraic topology, cohomology theories, and Poincare duality may find the discussion relevant, particularly those exploring the implications of compact support in various contexts.
Jamma
Hi there.
I'm looking at Poincare duality, and there's something extremely wrong with the way I'm looking at one or more of the concepts and I need to figure out which.
When dealing with non-compact manifolds, you can fix Poincare duality by looking at something called "cohomology with compact support". It mentions it on page 7 here:
http://www.math.upenn.edu/~ghrist/EAT/EATchapter6.pdf
It mentions there that you can restrict your cochains (singular, simplicial, cellular) to those which evaluate only on some compact subspace.
My confusion is that I don't understand how the boundary of a singular chain will necessarily be a singular chain with compact support (I can easily see it for the other two).
Take, for example, the 0-cochain which evaluates to 1 on a specific point and 0 elsewhere. The boundary of this chain (I think) will be the cochain which evaluates to 1 on all lines which start at the point and to -1 on all lines which end at the point.
So in that light I don't see how we get back something which is of compact support.
Oh, and another way to look at Poincare duality is to fix your homology theory instead - you can look at formally infinite chains for which every compact subset only intersects with finitely many chains. I can easily see here how the boundary map restricts.
I imagine I've gone embarrassingly wrong with my interpretation of the coboundary map.
It seems to me that you're attempting to compute the simplicial coboundary map. I think in order for compactly supported simplicial (co)homology to make sense, you need to restrict to simplices that are locally finite. This will ensure that the coboundary map is well-defined. In your computation for instance, the local finiteness ensures that there are finitely many lines coming in/out of the point of interest, so the coboundary of your "0-cochain" is indeed compactly supported.
For actual singular cohomology, the fact that the coboundary d*a of a compactly supported cochain a is again compactly supported follows from the fact that d*a=ad so supp(d*a) \subset supp(a) as a closed subset.
So in singular cohomology with compact support, you consider the subcomplex of C^k(X) of those singular k-cochains f having the property
(P) there exists a compact subset K of X such that f(c)= 0 for all k-chains c sitting outside of K.
To see that this is indeed a subcomplex, it suffices to observe that if f is such a compactly supported k-cochain, then d*f is the cohain that evatuates on a (k+1)-chain c thus: (d*f)(c) = f (dc). If c sits outside of K, then so does its boundary dc, hence f(dc) = 0. That is, d*f has property P also for the same compact set K as f.
I've found the solution to my problem. It's a very nuanced subtlety in the definition, it's mentioned here on page 5 in part of Hatcher's book:
http://www.math.cornell.edu/~hatcher/AT/ATcapprod.pdf
I think he anticipated the use of "compact support" that most people might naturally assume and addressed it there (indeed with exactly the same counter example that I stated).
The solution is that instead of forcing your cochains to evaluate to non-zero values on chains inside some compact subset, what you actually want is the subset of all cochains which evaluate to zero on all chains contained outside some compact subset.
The locally finite thing is important too though, thanks for your help.
Ahha, just beat me to it quasar, thanks though!
I strongly recommend that you look at Bott and Tu's development of Poincare Duality using differential forms. Thom classes of normal bundles fall out of this approach easily and actually use a somewhat different idea, cohomology with compact support along the fibers.
I find the Algebraic Topology version of this more techincal and less intuitive,
If you want to understand X, and if you can find X in Bott and Tu, then "read Bott and Tu's presentation of X" is usually a good piece of advice. :)
I'm trying to adapt something rather particular and need Borel-Moore homology, where you can have chains of non-compact support. This should be Poincare dual to (singular, simplicial, cellular) cohomology. I'll look up Bott and Tu's version anyway though, it always helps to see different perspectives on things.
I've seen the Thom isomorphism used to prove Poincare duality before actually. Indeed, looking at the wiki page for Poincare duality now, it mentions that this is a nice way since it proves Poincare duality for any generalised theory for any such theory which has a Thom isomorphism.
  • · Replies 23 ·
  • · Replies 19 ·
