Final Velocity of Two Objects After Collision
The discussion revolves around a collision problem involving two objects with different masses and velocities, specifically focusing on the final velocity after they collide and stick together. The context is set within a 6th-grade science framework, emphasizing the conservation of momentum.
  • Participants explore the application of conservation of momentum, questioning how to adapt the principle when both objects are in motion. Some express uncertainty about the correct formula and seek clarification on the calculations involved.
There is an ongoing exchange of ideas, with some participants providing hints and guidance without revealing complete solutions. Multiple interpretations of the problem setup are being discussed, and there is a mix of attempts to clarify the correct approach and calculations.
Participants note discrepancies in the mass of the objects mentioned, which may affect the calculations. There is also a mention of a lack of examples in the textbook regarding scenarios where both objects are moving, contributing to the confusion.
km
Need help determining the following:
A 50kg object moving at 20 m/s collides with a 10-kg object moving at 5 m/s. They stick together and move off together. What is their final velocity?
I know how to determine this if one object was stationary, but in this problem, both are moving. Help! 6th grade science problem
Hint: Conservation of Momentum. New object has mass of 60kg. If they are moving along the same axis - the calculation would be really simple
Still need to know what the final velocity is and what formula to use to get the answer.
km
Does your textbook tell you about anything in regards to conservation of momentum? Take a guess as to what the formula is...
I'm trying to guide you through it, and not just give you the answer...
Use the same principle as when one object is initially stationary, but apply a more generalized formula:
[tex]\vec{p}_{initial}=\vec{p}_{final}[/tex]
[tex](m_{1}\vec{v}_{1})_{initial}+(m_{2}\vec{v}_{2})_{initial}=(m_{1}\vec{v}_{1})_{final}+(m_{2}\vec{v}_{2})_{final}[/tex]
Can you go from there?
Never mine I think I got it.
Answer is 10m/s. I hope.
Thanks anyway.
km
That is incorrect. Can you show us your work?
First I determined the total momentum:
(5 kg x 20 m/s) + (10kg x 5 m/s) = 150 kg.ms
then determined velocity:
150kg.m/s = (5kg + 10kg) x velocity
10 m/s = velocity
this is what is in my textbook but there were no examples of both objects moving
The original question you posted says one mass is 50 kg. If it is 5 kg, as the latest version of the problem states above, you are correct, assuming both objects are initially traveling in the same direction.
OOPS! My mistake. Yes, the first object is 5-kg. Sorry for the mix-up on original posting. Thank you for letting me know this was correct!
Since you mentioned Conservation of momentum earlier, I also have another question I am working on that I am having trouble with as my textbook does not talk about rocketships!
The question is: How do you explain conservation of momentum when a rocket ship takes off?
What I have found on the internet so far says stuff about the the rocket ship pushing on the fuel and the fuel pushing on the rocket ship but I don't understand!
Momentum is conserved when we take the movement of a rocket ship with no fricitonal forces, etc.
[tex](m_{r}\vec{v}_{r})_{initial}+(m_{f}\vec{v}_{f})_{initial}=(m_{r}\vec{v}_{r})_{final}+(m_{f}\vec{v}_{f})_{final}[/tex]
where r is rocket (w/o fuel) and f is fuel. Since the rocket and fuel are initially traveling at the same velocity (before the engine is engaged), we can simplify this to:
[tex](m_{(r+f)}\vec{v}_{(r+f)})_{initial}=(m_{r}\vec{v}_{r})_{final}+(m_{f}\vec{v}_{f})_{final}[/tex]
Keep in mind that velocity and momentum are vectors here, so we need to consider direction. If we are speaking of linear displacement, we can simply define opposite directions as positive and negative; in that case, watch your signs!
  • · Replies 32 ·
