Optimizing Metal Cost for Cylindrical Can Construction
  • Context: Undergrad
  • Thread starter Thread starter courtrigrad
    Method
The discussion focuses on optimizing the cost of metal for constructing a cylindrical can with a volume of 100π in³. The cost of the top and bottom is 2.5 cents per square inch, while the sides cost 1.35 cents per square inch. The total cost function is derived as C(r) = 270π/r + 5πr², where r is the radius. To minimize costs, participants suggest setting the derivative of the cost function to zero to find the optimal radius and subsequently calculating the height.
  • Understanding of calculus, specifically derivatives
  • Familiarity with geometric formulas for volume and surface area
  • Knowledge of cost optimization techniques
  • Basic algebra for manipulating equations
  • Learn how to derive and solve optimization problems using calculus
  • Study geometric properties of cylinders and their applications
  • Explore cost minimization strategies in manufacturing
  • Investigate the implications of material costs on design choices
Manufacturing engineers, cost analysts, and students studying optimization in engineering design will benefit from this discussion.
courtrigrad
Hello all
For this problem:
3. A manufacturer wishes to construct a cylindrical can to hold 100 pi in^3. The top and bottom of the can are to be stronger than the sides. The tin used in making the top and bottom will cost 2.5 cents per square inch while the metal used in making the sides will cost 1.35 cents per square inch. What dimensions should be used to minimize the cost of the metal?
pi*r^2 = 100pi
Area of sides = 2pi*r*h
Area of top and bottom: 2pi*r^2
h = 100/ r^2
2pi*r(100/r^2) + 2*pi*r^2
Now do I multiply the cost of the sides by the coefficients?
Any help is appreciated
Thanks!
courtrigrad is online now Edit/Delete Message
You have "pi r^2= 100 pi" when, of course, it should be pi h r^2= 100 pi. (You knew that since you then have h= 100/r^2).
Yes, the 'cost' is the area of each part times the cost of each part: The cost of the side will be 1.35(2pi r)(100/r^2) (which is 270pi/r) and the cost of the top and bottom will be (2.5)(2 pi r^2)= 5pi r^2. The cost of the entire can is the sum of those:
270pi/r+ 5pi r^2. Set the derivative of that equal to 0 to find the value of r that makes that a minimum. Don't forget to find h too!
thanks a lot
