Proving Spring's Total Constant: 2k/3
  • Thread starter Thread starter joy
    Constant
The problem involves a spring system composed of two springs with different spring constants and lengths. The task is to prove that the effective spring constant of the combined system is 2k/3.
  • Exploratory, Problem interpretation, Assumption checking
  • The original poster expresses uncertainty about how to begin the problem and mentions relevant equations but feels unable to apply them. Participants suggest considering different configurations for connecting the springs and setting up equations for the equivalent spring.
Participants are exploring various interpretations of how the springs are arranged and discussing the relationships between forces and displacements in the system. Some guidance has been provided regarding the setup of equations, but there is no explicit consensus on the approach to take.
The original poster notes a lack of guidelines in their textbook, which may contribute to their uncertainty. There is also a suggestion that the problem might involve oscillation, although this has not been confirmed.
joy
Hi!
I haven't done anything with the following problem because I really don't know where to start from. My book doesn't give any guideline. The only thing I am aware of is F=-Kx and E=Kx^2/2 but I cannot use them to proceed in some way.
'' A spring of length l it is consisted of 2 springs. The first has constant k and length l/2 and the second has constant 2k and length l/2.
Prove that the constant of the hole spring is 2k/3.''
I am sorry for the bad english. My mother tongue is greek.
Thank you.
Welcome to PF joy!
1. Given two springs (and say a mass). How many ways can you connect the springs to the mass? (Hint: don't think about a mass sandwiched between two springs.)
2. Can you set up the equation for an equivalent spring and for the two "sub-springs"?
Hope that helps...(second hint: E = (1/2)kx^2 needn't be used)
Thanks for your help!
I have tried to use energy but it is still difficult. I realized though, that it is maybe a problem that needs oscillation...
maverick280857 said:
Welcome to PF joy!
Well, since the combined spring has length L and the two springs are length L/2, they must be attached end-to-end, or in series. So what does that mean. Consider Spring 1(Sp1) of spring constant k1, and Spring 2 (Sp2) with constant k2.
Sp 1 . . Sp2
|/\/\/|/\/\/\/| <-- F
Now force F pushes (or pulls) on the combined spring. What can we say about the force in each spring, in relationship to F. Let force in Spring 1 = F1 and Spring = F2. The forces are directly transmitted from F - to Sp 2 and from Sp 2 to Sp 1, so F = F1 = F2.
Now consider displacements x1 in Sp 1 and x2 in Sp 2.
F1 = k1x1 and F2 = k2x2, and the total displacement of the combined spring x = x1 + x2.
In the combined spring F = kx (and you wish to find k in terms of k1 and k2).
From the equilibrium conditions, remember x = x1 + x2, or
F/k = F1/k1+ F2/k2.
Now should be able to take it from here.
  • · Replies 18 ·
