More quantum mechanics nightmare
The discussion revolves around quantum mechanics problems, specifically focusing on calculating energy eigenvalues for particles in a one-dimensional box and harmonic oscillators. The original poster expresses frustration with the complexity of the problems and seeks guidance on how to approach them.
  • Participants discuss the general form of wave functions and boundary conditions for the potential in question. There are attempts to derive energy eigenvalues and questions about how to express these values in kJ/mol. Some participants explore the implications of quantum numbers and the relationship between energy levels.
Participants are actively engaging with the problems, offering hints and clarifications. Some have provided formulas for energy eigenvalues, while others are questioning the formulation and units. There is a mix of understanding and confusion, particularly regarding the application of concepts to different particles and the interpretation of results.
Participants note the need to compute energy eigenvalues for multiple particles (electron, proton, argon) and express concerns about the transition from individual energy levels to a general formula. There is also mention of textbook limitations in providing clarity on certain concepts.
jsundberg
More quantum mechanics nightmare :(
A new set of problems to solve, that's mostly problems. Makes me cry. :D
All I want is for christmas to come, but this has to be done.
A:
Calculate the energy eigenvalues for a electron in a one-dimensional box with the length 0.1nm. Express the result in kJ/mol. Extend your calculations to first a proton, then an argon atom (looked upon as a point particle without inner structure).
B: Starting from the guess that the right function for a energy eigenfunction for a harmonic vibration in a potential V(x) = 1/2kx^2 is psi(x) = xexp(-ax^2) verify the guess and calculate the parameter a and the corresponding energy eigenvalue En. The particle mass is m. What grade of excitation does this eigenfunction have? Normalise the wavefunction and caluclate the energyeigenvalue in kJ/mol if the particle is a proton and k = 200N/m.
Hints, pointers, everything appreciated. I need to understand this.
A: What is the general form the wave function must have for this potential? What are the boundary conditions (i.e. what does psi look like at the edge of the potential)? Think about wavelength in relation to the length of the box. So now that you have psi go back to schroedingers time independent, plug it in and out the eigenstates should come.
B: This is the same thing, but they already gave you the form so plug it in and show it works. Then the calulations should come easily.
Thanks for your time & help.
Still stuck, I think I'm stuck on more basic principles actually.
I think I've got the solution for the eigen values: En = n^2h^2/8mL^2
But how should I formulate this? Especially in kJ/mol.
I know h, m, and L (and those are constant).
should I just write En = n^2*constant1/constant2?
but that seems strange.
That energy level (labeled through "n") corresponds to a particle of mass "m".If "m" is in Kg,then 6.023*10^{23} particles of mass "m" make up a mol of particles.So compute E_{1} and multiply it with Avodadro's number(the one stated before) to find the energy per mol.Then do the same for "n=2" aso.
Daniel.
Thanks again!
Yes, but then I only get the energy eigenvalues for 2 quantum numbers. Shouldn't I find a general formula for n (unspecified) levels?
jsundberg said:
Thanks again!
If u computed the energy per mole for "n=1"(call it [itex]E_{1}[/itex]),then it's easy to write for arbitrary "n":
[tex]E_{n}=E_{1}n^{2}[/tex]
,where the units are J/mol,and "n" is a natural number different from zero.
Daniel.
Thank you!
You saved my day. :D
Physics is not my thing really.
jsundberg said:
Thank you!
Then what are doin' solving QM problems? :confused: You should be doing what u like,and not what causes u headaches and and frustration??
Physics student?Maybe it wasn't such a smart move. :rolleyes:
Daniel.
:D
No, I'm a chemistry undergrad, going for a major in organic chemistry. I need this course in physical chemistry though to be able to take my master. The thermodynamic part was fun, and not quite this challening. I'll just have to try to make it work, it's over in a few more weeks. :)
I have come so far to calculate the energy eigenvalues for the
electron, proton and argon atom:
En = n^2h^2/8mL^2
E1 = h^2/8mL^2
En = E1n^2
For the electron I got:
E1 = 3629kJ/mol
Proton:
E1 = 2kJ/mol
Argon:
E1 = 0.06kJ/mol
Now I'm going to compare the distance in energy between the ground
state and first excitated state between those three particles with RT
at the temperature 300K. The last part here confuses me a lot, RT? What do they mean? My textbook doesn't really help a lot :(
R is the ideal gas constant, T is the temperature. RT has units of energy/mol.
R = 8.314 J K^-1 mol^-1.
Okay, you must know temperature is actually a measure of the KE of the molecules. For an ideal gas, the absolute temperature (in Kelvin) is directly proportional to the KE.
So, for a single atom/molecule [tex]<\frac {1}{2} mv^2>~~ \alpha~~ T[/tex]
the proportionality constant [itex]k_B[/itex] is known as the Boltzmann Constant, and is accompanied by a prefactor of 3/2, which comes from the Equipartition Theorem.
So, [tex]<\frac {1}{2} mv^2> = \frac{3}{2} k_BT[/tex]
Thus, [itex]k_BT[/itex] gives you an estimate of the average KE of a molecule at temperature T. To extrapolate this equation to a mole of gas, you simply have to multiply by Avogadro's Number, [itex]N_{av}= 6.023*10^{23}[/itex] molecules/mole.
So, the average KE of a mole of gas, is roughly [tex]<\frac {1}{2} Mv^2> = \frac {3}{2}N_{av}k_BT = \frac{3}{2}RT[/tex]
where [tex]R = N_{av}k_B [/itex]<br /> <br /> To get an order of magnitude estimate, the 3/2 prefactor is often skipped. In fact, this prefactor is different for different kinds of molecules (see Equipartition Theorem).[/tex]
That's a bit embarassing. Don't know what I thought of, of course I know what
RT is. Thanks for all the help, again. You guys saved my day once again. :D
Gokul: Really good explanation! Thanks.
  • · Replies 16 ·
10K
