Counting with composites Please advise
  • Context: Undergrad
  • Thread starter Thread starter idiom
    Advise Counting
The discussion revolves around the concept of counting composite numbers and its implications for identifying prime numbers. Participants explore whether generating all composite numbers can lead to a complete understanding of prime numbers, particularly focusing on the relationship between odd composites and missing odd primes.
  • One participant questions the standard for counting with composite numbers and suggests that counting odd composites could lead to identifying all primes.
  • Another participant expresses skepticism about the solvability of the problem, noting that bounding values for primes exist rather than definitive counts.
  • A participant claims to have a method for generating all composite numbers and seeks validation for the proposition that missing numbers in this context would be primes.
  • Concerns are raised about the efficiency of algorithms for handling large numbers, with one participant suggesting that the time complexity of the proposed method needs consideration.
  • Some participants discuss the potential for using known primes and Mersenne primes to test the algorithm's effectiveness.
  • There is mention of the computational challenges associated with manipulating large primes and the need for algorithms that adapt to failures.
  • One participant shares a thesis that addresses the relationship between primes and composites, while expressing doubt about the feasibility of finding large primes satisfactorily.
  • Another participant reflects on the nature of primes as both intriguing and problematic, sharing a personal anecdote about a failed attempt to generate new primes from existing ones.
Participants express a mix of agreement and disagreement regarding the feasibility of the proposed methods and the relationship between composites and primes. There is no consensus on the validity of the claims made, and multiple competing views remain throughout the discussion.
Participants acknowledge limitations in their approaches, including the need for thorough testing of algorithms, the efficiency of methods for large numbers, and the inherent challenges in identifying primes based on composites.
idiom
Counting with composites... Please advise
What is the standard for counting with composite numbers?
If I can count to infinity with all odd composites and factor them, would that be considered key to counting all primes to infinity. By default all missing odd numbers in the sequence would be Prime. Having difficulty finding the precedent for this.
My composite number line is growing to infinity without missing a composite, so at what point can we say all primes are the numbers that fall between, which leaves us with all primes to infinity?
Please Advise.
I don't think this is solvable or has been solved. What you're saying is if you can count the composites in a given range of numbers then by simple arithmetic you'll know how many primes are there. I think we only have bounding values for the number of primes in a given range.
What I am actually saying is I can generate all the composites, that part of the problem is solved. Conversely I can also find all the composite factors.
and how exactly do you generate all the composites?
Have only tested the number set up to the first 100 primes. The original premise remains. If I can generate all composites (by themselves) then by default do I have all the primes? (the primes are the missing numbers from the set. As an example if I take the odd set of numbers ( 9 15 21 25 27) the primes are the missing odd numbers (11 13 17 19 23). If I run this set to infinity then the primes are the missing odd numbers. I would like a community consensus to validate my proposition.
check this definition in wikipedia basically a number is either composite or it is prime by definition. so if you can generate the list of composite numbers then the missing ones will be primes. The caveat is of course is if your algorithm truly filters out composites only.
http://en.wikipedia.org/wiki/Composite_numbers
Yes that is the caveat and right now it appears to be working perfectly. However I will need help setting the algorithm to test to very large numbers. I am very confident because the math is sound. Very excited about the fact the method can also be used to factor composite numbers quickly.
Thanks for the positive input. It seems obvious to me the result of generating each and every composite leaves nothing but primes, but the results seem almost too good to be true.
I have no reason to believe the results will falter for large numbers but of course more thorough
testing is needed.
But the problem isn't necessarily being able to create composites, it's being able to handle large numbers efficiently. What do you think the time complexity of your algorithm is? Answering that will tell you if you have a good method. If time didn't matter we could use the Sieve of Eratosthenes, but it's not feasible for large N.
Yes good point. The method allows targeting of a select segment without knowing the preceeding primes. If you are interested in a segment of large numbers you can generate the composites for that segment only. The Sieve of Eratosthenes appears incapable of doing that.
Found this web page on computational math
http://userpages.umbc.edu/~rcampbel/NumbThy/Class/BasicNumbThy.html
It has some discussion on primality tests... Which you find interesting...
If you're doing this via computer then you'll have to consider using a BigInteger package because you'll run into number limits for integers at 2^16 or 2^32 or whatever largest integer the CPU can handle. After that you need to use a software solution like BigInteger to get beyond it and software solutions run slower.
Yes I am considering very large numbers. That is what makes the method useful. I can zero in on specific number ranges without sieving an enormous quantity of numbers.
Well now I'm intrigued. if your technique does indeed work as you are saying, then I'm puzzled. You should consider making your work public. It's the best way to get true feedback.
Would have already posted, but there is a proprietary advantage of factoring very large numbers.
Indeed there is. Good luck with your work!
some things you can do to test your algorithm is to get a list of known primes and especially mersenne primes and try them out to see if they are factorable. Next would be composite numbers that passed some primality test to see if they are factored.
What language are you using for the algorithm?
Using a java app currently
thats good, its not the fastest but is a very useful language for math exploration.
Not directly connected to your work but useful info:
You should look into log4j logging so that you can track your algorithm as it does its computations. log4j collects and prints runtime info to a log along with the message text you provide. I use it to collect timing between statements. Its something that can be turned on and off via a properties file.
Another tool you might consider is the Open Source Physics toolkit which has charting capabilities that you could use to plot results or timings as you estimate the speed of your algorithm with larger and larger numbers.
H2 Database, a pure java-based database useful for storing your results or factorings... in a searchable fashion without worrying about data storage limits.
Some other cool things to check out:
- using scala instead of java, scala is statically type OO + Functional Programming language
- NetBeans for development IDE
Good luck on your quest.
Fantastic thanks for the info:
Hope it's not too late to offer my insight. The notion of grappling the problem of primes via composites definitely has precedent. I offer the following thesis:
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0BzmRGf7l85GRNzNhZWQ4MzAtMDMzNC00ZjY4LWJlNzQtMjBlNTQ0OGJiM2U0&hl=en_US&pli=1
This is posted on my research website. I hope it can offer you some insight.
https://sites.google.com/site/primenumbertheory/
It is however, my contention that the computational difficulty involved in manipulating/finding sufficiently large primes will never be solved with great satisfaction.
Shalom
i agree so far every algorithm tried has failed. It seems that you need an algorithm that shifts gears when the previous one fails or learns from its failures.
Like the n^2 + N + 41 for n<=40 developing an algorithm to modify the equation for the next range and then then next... and determining what the new range is.
Just thinking.
Indeed, also from my own experience in number theory this particular problem seems like one that demands the very information you are trying to obtain in order to solve it. In this way primes are both a fascinating enigma and a rather bothersome artifact of the set of naturals.
very true. I once had an epiphany where I was thinking so if I take a list of primes and make a product then add one I'll have a new prime to add to my list (I was impressed by Euclid's proof). But I assumed that it was the next prime which it wasn't and so another great idea comes crashing down.
2 . 3 = 6 ==> 7
2 . 3 . 7 = 42 ==> 43
2 . 3 . 7 .43 = 1806 ==> 1807 which factors into 13x139 bust!
The solution presented seems to have the problem of being non-deterministic. I am offering a deterministic solution for discussion. That is we can precisely calculate all of the composites in a deterministic fashion for any given number range. The primes themselves are the numbers missing from the sequence of composites.
So the question put forth is there any other methods of deterministic composite number generation?
Speaking as a mathematician, deterministic means not probabilistic. The solution offered is deterministic but on a heuristic time scale. To my knowledge all such deterministic algorithms are in this way lacking. There are many probabilistic seekers/tests as well. The sieve of Eratosthenes is the most simple prime algorithm. It too is deterministic and seeks primes by determining composites, but it is very heuristic.
Sorry about my terminology. Would you consider directly calculating all the composite numbers (Composites) in a range ( any give range you pick) heuristic? Or is it just heuristic if you use the result to find primes?
When I say directly I mean each iteration gives a valid result.
Both are actually heuristic (given what is generally common to academia and what I have observed from my own research). That doesn't mean yours is heuristic -it is possible you have discovered something others have missed.
Mathematicians seek a transcendental function --call it P such that a natural value input corresponds to a unique prime number. Now the word transcendental is used with regard for the underlying rigor: it has been proven --in fact has long since been proven-- that no polynomial will generate primes nor any algorithm that is reducible to a polynomial.
Now when it comes to what you speak: finding primes by determining the compliment --the set of composites-- this has been approached in a myriad of different ways --all of them very heuristic (logarithmic computing time/effort). The problem is if you have an algorithm that generates all composites and then fills those empty nodes with the primes you are either using a program that is flawed, recursive, non-deterministic, or is storage consuming. In any case the prognosis is poor. I should qualify this by saying that I am not yet old enough and jaded enough to believe it impossible that you haven't found a better idea than anybody else; it just seems unlikely.
Best reply on the board yet! I have looked at a myriad of methods just as you describe and I agree with your conclusions. As for the primes themselves they manifest themselves in the calculations which a mathematician of your caliber could probably extract more efficiently then me. I have found the method to be much more efficient for factoring composites then anything I have been able to find, which also makes for a good primality test.
Believe I can eliminate flawed and non-deterministic. There is storage consumption but I believe it is a much smaller scale then conventional methods. The efficiency becomes particularly apparent when using a targeted range.
Hi, idiom,
do you have already a "big number" implementation of your algorithm? If so, could you post the elapsed time of your algorithm when factoring each of the numbers of the sequence 10^n+1, for as large an 'n' as you can wait? Namely, in pseudocode,
n=1
while true {
n = n * 10
factor(n+1) // and print the elapsed time of this computation
(If you don't have yet a "big number" implementation, obviously the next step is to write one.)
  • · Replies 25 ·
