Understanding the Product Rule: Deriving and Proving Its Validity
  • Context: Undergrad
  • Thread starter Thread starter Patrix0
    Product Product rule
The discussion revolves around the derivation and proof of the product rule in calculus, as well as the irrationality of numbers such as pi and e. Participants explore various methods for deriving the product rule and share insights into proofs of irrationality, including references to specific mathematical techniques and theorems.
  • One participant expresses familiarity with the product rule but seeks clarification on its derivation.
  • Another participant suggests starting from the definition of the derivative to derive the product rule.
  • Multiple participants discuss various proofs of the irrationality of e, including a proof using the definition of e and another involving power series.
  • One participant mentions a proof of pi's irrationality attributed to Ivan Niven, detailing a method involving calculus and contradiction.
  • Several participants share their thoughts on the complexity of proofs for irrationality, noting that proofs often rely on contradiction.
  • Another participant provides a detailed derivation of the product rule using limits and simplification techniques.
  • Some participants reflect on the elegance and clarity of different proofs and derivations presented in the discussion.
Participants do not reach a consensus on the best method for deriving the product rule or the most straightforward proof of irrationality for numbers like e and pi. Multiple competing views and methods are presented, indicating a lack of agreement on a singular approach.
Some proofs and derivations discussed rely on specific mathematical definitions and theorems, which may not be universally accepted or understood by all participants. The complexity of the proofs and the assumptions made in each case are acknowledged but not resolved.
This discussion may be useful for students and educators in mathematics, particularly those interested in calculus, differentiation, and the properties of irrational numbers.
Patrix0
Hi all!
I've been working with differentiation for quite some time now, and I know how to use the product rule.
f(x) = u(x)*t(x)
f'(x) = u'(x)*t(x) + t'(x)u(x)
But what I don't understand is how one derives it... :cry:
Oh, and one more thing.
How do we know a number is irrational, like pi and e ?
Like, how do we know that it has an infinite number of decimals?
Is it because when you do the decimal operation you will eventually see that there's a sequence of decimals which repeats itself, or not? Something else perhaps?
Thanks in advance.
Hi, it can be derived using the definition of the derivative. Start with:
[tex]f'(a)=\lim_{h\rightarrow 0}\frac{f(a+h)-f(a)}{h}[/tex]
Now use the fact that f(x)=u(x)*t(x). Do you want to try to proceed on your own?
Proving a number like pi or e is irrational can be tricky. I think there's a post somewhere here where HallsOfIvy posted one of the easier proofs, I'll see if I can find it.
edit-aha! https://www.physicsforums.com/showthread.php?t=8193 The method was originally by I. Niven though Halls is probably referring to an article of A. Parks, who generalized it. It's not short, but it's accessible after first year calculus.
That seems a remarkably uneasy* proof of the fact that e is irrational, which can be done from first principles merely from the definition of e.
let e=p/q, where p and q have no common factors
consider p(q-1)! - eq!
the resulting number can be shown to be both integer and between 0,1 and not equal to either. contradiction, hence e is irrational. It's a proof in the first year of any maths course.
irrationality of pi is harder.
* in the sense of one has to prove more complicated theorems to use it
Pictures sometimes help (of course, sometimes they don't). Suppose you have a rectangle with a width of u and a height of t. How does the area change if you adjust u and t by small amounts? (Say, by an amount of Δu and Δt respectively)
Absolutely, but for pi it's decent. Getting e is a nice bonus, though it also gets e to the power of any non-zero rational for free too.
I should have pointed out the simpler method for e, thank you. Though it's not p(q-1)! - eq! that will be an integer between 0 and 1, but q! times the terms in the infinite series for e after the qth term (maybe I'm misreading).
no, you're probably correct, few too many beers not helping my brain
Let there be a y = uv, where u = g(x), v = q(x) and y = f(x)
y = uv,
y+dy = (u +du)(v+dv) = uv + udv + vdu + dudv
then dy = udv +vdu + dudv,
dudv moves toward zero thus,
dy/dx = u(dv/dx) + v(du/dx) which is f'(x) = [g(x)]q'(x) + [q(x)]g'(x)
Patrix0 said:
Hi all!
f(x) = u(x)*t(x)
i would use the mean-value theorem:
[tex]f'(x) =\lim_{x\rightarrow y} \frac{f(x)-f(y)}{x-y}[/tex], [tex]g'(x) =\lim_{x\rightarrow y} \frac{g(x)-g(y)}{x-y}[/tex],
Thanks in advance.
for e i think the proof uses power series, for pi,
let [tex]\pi = a/b[/tex] where a & b are positive integers, and let
[tex]f(x) = \frac{x^n(a-bx)^n}{n!}[/tex]
[tex]F(x) = f(x) - f^(2) (x) + f^(4) (x) - ... + (-1)^nf^(2n)(x)[/tex]
since [tex]n!f(x)[/tex] has integer coefficients & terms in x whose degree is at least n, f(x) & its derivatives have integer values @ x=0, and also for [tex]x= \pi = a/b[/tex]
(note that [tex]f(x) = \frac{b^n}{n!}(\pi - x)^n[/tex], so [tex]f(x) = f(\pi-x)[/tex] ).
from calculus,
[tex]\frac{d}{dx} [F'(x)sin(x) - F(x)cos(x)] = F''(x)sin(x) + F(x)sin(x) = f(x)sin(x)[/tex]
and [tex]\int_{0}^{\pi} f(x)sin(x) dx = [F'(x)sin(x) - F(x)cos(x)]^\pi_0 = F(\pi) - F(0)[/tex], an integer, since the ith derivative of f evaluated at 0 & at [tex]\pi[/tex] are integers. but for [tex]0 < x < \pi[/tex],
[tex]0 < f(x)sin(x) < \frac{\pi^n a^n}{n!}[/tex]
so that the integral is positive, but arbitrarily small for large n, since (another result from calculus) [tex]\lim_{n\rightarrow \infinity} \frac{x^n}{n!} = 0[/tex],
contradicting the fact that the integral above is an integer. so [tex]\pi[/tex] is irrational (that's ivan niven's excellent proof; i got it as a handout in a course i did last spring)
it seems that most proofs of irrationality are by contradiction. the proofs that e, pi & square roots of a (non-square) numbers are all donce by pretending that they are rational, setting them to a/b & going from there
Thanks for your help guys! I'll do my best to understand!
There are definitely more elegant derivations of the product rule. But here's one way:
Let r(x)=p(x)q(x).
Let s(x,h)=[p(x+h)-p(x)]/h, h is not 0
Let t(x,h)=[q(x+h)-q(x)]/h, h is not 0
r'(x)
=limh->0[p(x+h)q(x+h)-p(x)q(x)]/h
write p(x+h) in terms of s(x,h) and q(x+h) in terms of t(x,h)
r'(x)
=limh->0[(hs(x,h)+p(x))(ht(x,h)+q(x))-p(x)q(x)]/h
Multiply out the numerator and simplify
r'(x)
=limh->0 [h^2s(x,h)t(x,h) + p(x)ht(x,h) + hs(x,h)q(x)]/h
=limh->0 h^2s(x,h)t(x,h)/h + limh->0 p(x)ht(x,h)/h + limh->0 hs(x,h)q(x)/h
=limh->0 hs(x,h)t(x,h) + p(x)limh->0 t(x,h) + q(x)limh->0 s(x,h)
Note that limh->0 t(x,h)=q'(x) and limh->0 s(x,h)=p'(x)
r'(x)
=p'(x)q'(x)limh->0 h + p(x)q'(x) + q(x)p'(x)
=0 + p(x)q'(x) + q(x)p'(x)
=p(x)q'(x) + q(x)p'(x)
Here is the clearest proof I've seen: http://planetmath.org/encyclopedia/ProofOfProductRule.html
what about this:
[tex](fg)'(x) = \lim_{y \rightarrow x} \frac{ (fg)(y) - (fg)(x)}{y-x} = \lim_{y \rightarrow x} \frac{ f(y)g(y) - f(x)g(x)}{y-x} = \lim_{y \rightarrow x}\left( f(y) \frac{g(y) - g(x)}{y-x} + g(x) \frac{f(y) - f(x)}{y-x}\right) = f(x)g'(x)+f'(x)g(x)[/tex]
Sorry to disspoint you,but that's the traditional method of proving it.I was taught this method in school,when in the 11-th grade.
It's nothing spectacular in it,just elegance.
Daniel.
