Are A and B subsets of R \ {0}?
  • Context: Undergrad
  • Thread starter Thread starter foreverdream
    Sets
The discussion revolves around whether the sets A and B are subsets of the real numbers excluding zero (R \ {0}). Participants explore the relationships between the two sets defined in terms of their elements and attempt to prove subset relations A ⊆ B and B ⊆ A, while grappling with the implications of the conditions on the variables involved.
  • Some participants define the sets A and B and express the need to show A ⊆ B and B ⊆ A.
  • One participant suggests that to prove B ⊆ A, it is necessary to show that the range of (x,y) in B lies within that of A.
  • Another participant expresses confusion about how to relate the variable t to the elements of the sets, particularly in the context of proving subset relations.
  • There is a discussion about the conditions t ≠ 0 and x ≠ -1, with some participants noting the importance of these conditions in establishing the subset relationships.
  • One participant proposes that if both sets contain values that are subsets of R \ {0}, then the subset argument can be used to complete the proof.
Participants do not reach a consensus on the proofs for the subset relationships, and there are multiple competing views on how to approach the problem. Some express uncertainty about the relationships between the variables and the implications of the conditions.
Participants note that the discussion involves assumptions about the definitions of the sets and the conditions on the variables, which may not be fully resolved. There are also mentions of needing to formalize arguments further, indicating potential gaps in the reasoning presented.
foreverdream
& means belong to and # not equal to : $ subsets of
A={(t-1,1/t): t&R, t # 0}
B= {(x,y) &R^2:y=1/(x+1), x#-1}
i started by say A$B
let x= t-1 and y=1/t
so we have y= 1/(t-1)+
= Y=1/t hence A$B
to prove B$A
is where i am stuck- as I think I have got my first part wrong anyway and I ma not sure if I have to make reference to x#-1 ot t#0
this is a fairy new topic for me and I am finding it bit abstract!
Thanks
= Y=1/t hence A$B
to prove B$A
Thanks
Hey foreverdream and welcome to the forums.
For the B$A you just have to show that the range of the (x,y) in B lies in that of (x,y) of A. So for the x you know that for (t-1), then t != 0 which means t != -1 which is the same for B. Since the structure is the reals you have shown that since x is a real and the reals are a subset of the reals then you have done it for x. (Its a property that A is a subset of A for any set A and its only a couple of lines to show this)
Based on the above hint, can you see how to prove it for the y coordinate?
so if I understand it correctly:
we must show that (x,y) belongs to B
but lost completely on t! part
let t-1=x and then y=1/(x+1) = 1/(t-1)+1 = 1/t
so (x,y)=(t-1, 1/t) hence A=B ? where does t! fit in-?
You have to show that in the second B$A part of your 2-tuple (the y coordinate), that all the values for this are inside.
I think you know intuitively what to do, but I don't think its formal enough. For your A set in the second part of your 2-tuple you have 1/t where t != 0 and for B you have 1/(x+1) where x != -1. So we know that t != 0 and x + 1 != 0 => x != -1 so that means there is nothing disjoint in those two sets. This is important because if there is anything disjoint then there is no way of subsets happening.
After that you who that that both are subsets of R \ {0} and since A is always a subset of A you have proven it for the 2-tuple (the y part).
In terms of making the above more formal you can show that both parts of the two tuple are the set R \ {0} (This just means the real numbers without 0). Once you do this then you use the subset argument listed above to complete the proof.
You shouldn't have to get any more formal than that.
  • · Replies 0 ·
