Angular Momentum: Physics Demonstration & Math Behind It
The discussion focuses on the physics of angular momentum and its demonstration using a gyroscope. The spinning wheel maintains its orientation due to high angular momentum in one direction while experiencing torque from gravity in another direction, resulting in a phenomenon known as precession. The conversation highlights the relationship between linear momentum and the net torque acting on the gyroscope, emphasizing the mathematical principles involved, such as force (F), mass (m), and the angle (θ). The participants express a desire to understand the underlying math more clearly.
  • Understanding of angular momentum concepts
  • Familiarity with gyroscopic motion and precession
  • Basic knowledge of torque and its effects on rigid bodies
  • Mathematical skills involving force, mass, and angles
  • Explore the mathematical derivation of angular momentum in rigid bodies
  • Study the principles of gyroscopic stability and precession
  • Learn about the relationship between torque and angular acceleration
  • Investigate real-world applications of gyroscopes in navigation systems
Students of physics, educators demonstrating angular momentum concepts, and anyone interested in the mathematical foundations of gyroscopic motion.
Alkatran
We had a demonstration in physics, which I'm sure most of you have seen, of a wheel spinning very quickly maintaing it's orientation. (There is a string hooked to one end of the axle, and you expect the wheel to 'flop' downwards)
Now, I was just wondering what the math behind this is?
The spinning wheel has a high angular momentum in direction X while there is a torque from gravity in direction Y: after that...? This is definitely similar to it being difficult to slow an airplane rather than a ball.
The spinning wheel is typically called a gyroscope, and the movement is referred to as precession.
I'm pretty sure that it's possible to work things out starting from linear momentum to see that there's a net torque on the wheel as a rigid object by, for example, looking at the necessary change in velocity of point masses along various places on the gyroscope to tilt the axle while the wheel remains spinning.
F=force
m=mass
0=theta
I want to say F=mdcos0 but I am not 100% sure, and in physics when we are not 100% sure we say were just guessing.
  • · Replies 39 ·
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 60 ·
