What Happens to Photons Near a Black Hole?
Photons near a black hole exhibit various behaviors based on their proximity to the event horizon. They can bend around the black hole, fall into it, orbit it, or pass by unchanged. The photon sphere, a critical boundary, allows photons to orbit but is dynamically unstable, meaning any slight perturbation can lead to either escape or capture by the black hole. Light emitted from within the photon sphere can reach outside observers only if it originates from regions outside the event horizon.
  • Understanding of black hole physics and general relativity
  • Familiarity with the concept of the photon sphere
  • Knowledge of event horizons and their implications for light behavior
  • Basic principles of stellar luminosity and temperature
  • Research the dynamics of the photon sphere and its stability
  • Explore the effects of gravitational lensing near black holes
  • Study the relationship between stellar radius and luminosity using the Stefan-Boltzmann Law
  • Investigate the implications of light behavior in extreme gravitational fields
Astronomers, astrophysicists, students of physics, and anyone interested in the behavior of light in extreme gravitational environments.
amy21
1. Photons approaching a black hole will initially
a. all of the above are possible depending on distance from the event horizon
b. pass by with their direction changing (bending/curving)
c. fall into the black hole
d. go into orbit around the black hole
e. pass by without changing direction
am thinking the answer is between d/ a because
The photon sphere is a spherical boundary of zero thickness such that photons moving along tangents to the sphere will be trapped in a circular orbit. The orbits are dynamically unstable. hence any small particle of infalling matter will grow over time, either setting it on an outward trajectory escaping the black hole or on an inward spiral eventually crossing the event horizon.While light can still escape from inside the photon sphere, any light that crosses the photon sphere on an inbound trajectory will be captured by the black hole. Hence any light reaching an outside observer from inside the photon sphere must have been emitted by objects inside the photon sphere but still outside of the event horizon.
since there's nothing above "a", this one's going to be hard to evaluate.
As for the rest, do you think maybe there might be some difference depending on whether the photons are aimed directly at the BH or way off to one side?
that is what confused me because they all can happen just depends on distance from the event horizon and since there was no option above a i was confused .
but thanks!
a quick question if there are Two stars that have the same temperature, but one has twice the radius of the other. The luminosity of the larger star compared
to the smaller star will be how great? .. am thinking it would be 2twice as great right ?
  • · Replies 40 ·
  • · Replies 20 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 62 ·
10K
