What Causes Buoyancy in Water? Answers and Explanations
  • Context: High School
  • Thread starter Thread starter chevap
    Buoyancy
The discussion revolves around the concept of buoyancy in water, exploring its causes and the effects of various object shapes and conditions on buoyancy. Participants examine theoretical aspects, practical scenarios, and the implications of Archimedes' principle.
  • One participant questions whether buoyancy is solely due to pressure differences above and below an object.
  • Another participant asserts that buoyancy is the net upward force resulting from pressure variations with depth, referencing Archimedes' principle.
  • A participant raises a scenario involving a thin object in water, suggesting that the buoyant force would still equal the weight of the displaced fluid.
  • Concerns are expressed about a perfectly shaped cone at the bottom of a glass, questioning which pressure would lift it if its density is less than that of water.
  • Another participant responds that if there is a perfect seal between the cone and the bottom of the glass, the water pressure would exert a net downward force, preventing the cone from rising.
  • Discussion shifts to the behavior of a steel needle placed on water, with participants noting that surface tension becomes a significant factor in this scenario.
  • One participant remarks that Archimedes' principle does not apply in the case of the needle resting on the water's surface.
Participants express differing views on the conditions under which buoyancy operates, particularly regarding the effects of seals and surface tension. There is no consensus on the implications of these scenarios.
Participants discuss various assumptions, such as the nature of seals between objects and the role of surface tension, which may affect the outcomes of the scenarios presented.
chevap
Hello.
I have a question or two about buoyancy, in water specifically. What causes buoyancy, if there is something more than the difference of pressures above and beneath an object?
What would happen if I put a very thin object in water, so that the difference in pressures would be extremely small?
And what would happen if I put an object (cone, for example) at the very bottom of a water filled glass, would it come back up (supposing it wouldn't sink if I just put it in the glass), and why? Which forces would affect the object?
English is not my native language, so I can't express myself the way I want to, but oh well.
That's all there is to it: Buoyancy is the net force on an object due to the pressure of the fluid surrounding it. There's a net upward force because pressure varies with depth.
It doesn't matter. The buoyant force would still equal the weight of the displaced fluid. (That's Archimedes' principle.) Of course, a thin object will displace less fluid than a fat object (of the same length).
If the density of the object is less than that of water, then the buoyant force will be greater than the weight of the object: thus the object will come back up. The forces acting on the object are: its weight (acting down) and the buoyant force of the water on it (acting up).
And welcome to PF!
Hmm, I can understand all that, but there's one problem that keeps bothering me.
If we have a perfectly shaped cone at the bottom of a glass, with no water beneath it, which pressure will lift it up (assuming its density is less than the density of water)?
If you have a perfect seal between the cone and the bottom of the glass, then the water pressure will exert a net downward pressure on the cone. There will be no "buoyant" force and the cone will not rise up.
Okay, thanks a lot!
And what happens if you put a steel needle onto the water?
If you put the needle (gently) onto the water (instead of into the water) then other factors come into play, such as surface tension. :wink:
Right :!)
And Arquimedes Principle is not satisfied. That astonished me some time ago.
:biggrin: :rolleyes:
  • · Replies 38 ·
