New Reply
Hooke's Law: Spring, Distance and Time
Share Thread Thread Tools
Jan28-12, 08:19 PM   #1
A mass M = 0.454 kg moves with an initial speed v = 2.88 m/s on a level frictionless air track. The mass is initially a distance D = 0.250 m away from a spring with k = 876 N/m, which is mounted rigidly at one end of the air track. The mass compresses the spring a maximum distance d, before reversing direction. after bouncing off the spring, the mass travels with the same speed v, but in the opposite direction.
a. Determine the maximum distance that the spring is compressed (0.0656 m).
b. Find the total elapsed time until the mass returns to its starting point (0.245 s).
2. Relevant equations
F = -kx
3. The attempt at a solution
a. Tried to use energy conservation equation but couldn't get the correct answer.
1/2mv0^2 + 1/2kd^2 + 1/2m1v^2 = 0.
got d = √(2mv^4/k) which got me an incorrect answer.
b. have no idea where to begin
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan28-12, 08:40 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by kgal View Post
The line in red is incorrect. The change in KE = work done by the spring. So you should have
1/2m(v2-v20 = 1/2 kd2
And you know that v=0. This should get you the correct value for d.
Jan28-12, 09:46 PM   #3
Thanks alot!
Jan28-12, 09:59 PM   #4
for section b,
I was thinking of using the equation x(t) = Acos(sqrt(k/m)t) where x(t) = 0.25 m, k from the answer in section a and the given mass, but can't get anywhere when trying to solve for t...
Jan28-12, 10:14 PM   #5
Recognitions:
for section b,
The mass starts out 0.250m away from the spring... it's not even in contact with it. It first travels that distance at its initial constant velocity before coming in contact with the spring. Then it compresses the spring by the distance found in part (a) and is subsequently launched back along its initial trajectory.
You'll have to divide the problem into separate parts corresponding to when it is in contact with and not in contact with the spring. When it's in contact with the spring you can use properties of a mass-spring system that you should know.
New Reply
Tags
distance, energy conservation, hooke's law, spring compression, velocity
Thread Tools
Similar Threads for: Hooke's Law: Spring, Distance and Time
Thread Forum Replies
Hooke's Law. Does this spring... Introductory Physics Homework 4
Spring and hooke's law Classical Physics 1
Ideal Spring and Real Spring Difference? (Hooke's Law) Introductory Physics Homework 10
Hooke's law with a spring Introductory Physics Homework 3
Hooke's law with spring Introductory Physics Homework 2
