Magnitude of Displacement problem
The problem involves a fly moving within a rectangular room defined by specific dimensions, with questions regarding the magnitude of displacement and the potential lengths of its path. The subject area includes geometry and vector analysis.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the nature of displacement versus path length, questioning whether the path length can be less than, greater than, or equal to the magnitude of displacement. There is also an exploration of how to express the displacement vector in component form.
Some participants have provided hints and guidance regarding the interpretation of the questions, particularly focusing on the geometric aspects of the problem. There appears to be a productive exchange of ideas, although no consensus has been reached on all parts of the problem.
The original poster expresses uncertainty about how to approach the problem, indicating a need for clarification on the questions posed. The discussion includes hints that suggest visualizing the problem through sketches and geometric reasoning.
KrissyFivee
A room has dimensions 3.15 m (height) 3.85 (width) m 4.10 (length) m. A fly starting at one corner flies around, ending up at the diagonally opposite corner.
(a) What is the magnitude of its displacement? (solved and got 6.45m)
(b) Could the length of its path be less than this magnitude?
(c) Could the length of its path be greater than this magnitude?
(d) Could the length of its path be equal to this magnitude?
(e) Take xyz axes so that the x-axis is parallel to the width, the y-axis is parallel to the length, and the z axis is parallel to the height. Express the components of the displacement vector.
(f) If the fly walks rather than flies, what is the length of the shortest path it can take? (Hint: This can be answered without calculus. The room is like a box. Unfold the walls and flatten them into a plane.)
|A| = sqrt(A^2+B^2+C^2)
I don't even know where to begin with this problem . . .
So far all I've got is the displacement is 6.45m, which is correct.
Hint for b,c, and d:
The shortest distance between two points in space is a straight line.
For part e, I think the question is looking for the i,j,k components of the displacement vector so they are talking about a straight line. From the starting position, what are the components of the displacement.
For part f, sketch the box unfolded then eyeball the shortest path on the surface of the unfolded box. Determine its length by using a method like the one you used in part a.
Thank you for the help :) I got it! I just didn't understand what the question was asking for!
Good!
