How Does Friction Affect the Work Done in a Closed Loop?
  • Thread starter Thread starter UrbanXrisis
    Energy
The discussion revolves around the effects of friction on the work done when sliding a block in a closed loop on a surface. The scenario involves moving the block at a constant speed along a rectangular path, raising questions about the relationship between work, kinetic energy, and friction.
  • Participants explore the implications of constant speed on kinetic energy and work done, questioning whether work is zero due to no change in kinetic energy. They discuss the role of friction and the forces involved in maintaining constant speed.
There is an ongoing exploration of the concepts of work and energy, particularly regarding the net force and individual forces acting on the block. Some participants have provided insights into the distinction between net work and work done by individual forces, while others are questioning the conservation of energy in different scenarios.
Participants are considering different surfaces (frictional vs. frictionless) and the implications of these conditions on energy conservation and work done. There are references to specific formulas and the need for additional information to apply them effectively.
UrbanXrisis
Sliding a block on a floor that has friction. Going from points A to B to C to D then back to A. points ABCD make a rectangle. Moving the block at a constant speed. What is the work done by the closed loop?
Since speed is a constant, then there isn't a change in KE, so then work done has to be zero right?
What if I did this on a frictionless table? Would the work done be zero as well?
The work done by what force? To move that block a force must be applied to overcome friction. That force does work which ends up increasing the internal energy of the block + floor. (They heat up.)
The work-energy theorem says that the work done by the net force on an object will equal the change in KE. But the net force is zero, thus no change in KE.
If you applied the same force, the block would accelerate and the work done would equal the change in KE of the block. To move the block at a constant speed requires no force (ignoring those corners!).
"Since speed is a constant, then there isn't a change in KE, so then work done has to be zero right?"
The work of the NET force is zero, but this doesn't mean that the work from the individual forces (friction and pushing force) are each zero.
The individual forces' work is most certainly not zero, only their SUM.
Work isn't zero for individual forces just like urban said. On a frictional surface conservative energy isn't conserved thus W(neoconservative)=change(mgh)+0 KE...The force is neoconservative in this case I think thus W(nc of friction)=mgh if you have those variables of h and m.
Does this mean there is no change in KE?
If the net force is zero, no work is done and the KE does not change.
so there is no change in KE for frictionless or friction surfaces?
How do you know if energy is conserved or not?
If the object moves at constant speed how can the KE change? :smile:
I'm not sure what you mean:
(1) For the frictionless surface, no energy is added (no work is done by an outside force) so energy is certainly conserved.
(2) For the friction surface, work must be done by an applied force. That work goes to heat. But no net work is done on the object, so its mechanical energy is conserved.
Hey, couldn't you just use this formula:
[tex] W = ( \mu mg \cdot \vec{F}_\textrm{normal} ) ( AB + BC + CD + DA )[/tex]
This depends of course on what information you've got.
Edit: made a correction to the formula
The formula [tex]W = ( \mu mg \cdot \vec{F}_\textrm{normal} ) ( AB + BC + CD + DA )[/tex]does indeed work. But remember that work equals
force times displacement, not distance. The displacement (net distance traveled) in this case is zero, so the work is zero. If you want to show this, make CD and DA negative distances.
OK, I see. Thanks for clearing that up.
What's this formula supposed to be? What do you mean by [itex]\mu mg \cdot \vec{F}_\textrm{normal}[/itex] ?
  • · Replies 33 ·
