Register to reply
How to derive impulse response from characteristic impedance
by edaffade
Tags: characteristic, derive, impedance, impulse
Share this thread:
edaffade
#1
Jan29-12, 02:34 PM
P: 4
i have a coax cable that will be used in data transmission. i have measured the open and short impedance and then characteristic impedance(Zo) for the cable. Eventually I will have a transmitter with Z_source in one end of the cable and receiver with Z_load at the other end of the cable. Is it possible to derive impulse response as a function of Zo,Z_source and Z_load?
Phys.Org News Partner Engineering news on Phys.org
Greater safety and security at Europe's train stations
Fingerprints for freight items
On the way to a safe and secure smart home
yungman
#2
Jan29-12, 03:02 PM
P: 3,898
Unless the bit rate width is much longer than the coax line, it is not adviceable to to mismatch the source, line and termination impedance. Reflection will create a step change on the logic level and cause error.
In digital communication, you don't deal with standing wave and those, either you have it or you don't.
edaffade
#3
Jan29-12, 03:57 PM
P: 4
They all will be matched but i want to analyze the effects of mismatches on BER using impulse response to see how much mismatch is tolerable.
yungman
#4
Jan29-12, 05:02 PM
P: 3,898
To do that, you have to know the threshold of the input of the receiver first, that is the most important thing. Then look up the transmission line reflection on step function. Usually only the first reflection step is the biggest and is proportion to the line and termination mismatch.
Register to reply
Related Discussions
Frequency response and Impulse Response Engineering, Comp Sci, & Technology Homework 1
Voltage step response of impedance frequency response Electrical Engineering 5
What is the difference between pulse response and impulse response? Engineering, Comp Sci, & Technology Homework 3
Characteristic impedance and transfer function Engineering, Comp Sci, & Technology Homework 2
Atomic Derivation of the characteristic impedance of the vacuum Atomic, Solid State, Comp. Physics 4
