Double Integral of f(x,y) in a Triangle Domain
The discussion focuses on calculating the double integral of the function f(x,y) = (2x+3y)^2 over a triangular domain defined by the vertices (-1,0), (0,1), and (1,0). The integral is set up with bounds from 0 to 1 for y, and from y-1 to 1-y for x. The integral is expressed as three separate integrals: ∫_0^1 ∫_{y-1}^{1-y} 4x^2 dx dy, ∫_0^1 ∫_{y-1}^{1-y} 12xy dx dy, and ∫_0^1 ∫_{y-1}^{1-y} 9y^2 dx dy. The integration process utilizes the power rule and results in a simplified expression ready for further evaluation.
  • Understanding of double integrals in calculus
  • Familiarity with triangular domains in integration
  • Knowledge of the power rule for integration
  • Ability to manipulate algebraic expressions
  • Study the properties of double integrals in calculus
  • Learn how to set up integrals over non-rectangular regions
  • Explore techniques for simplifying complex integrals
  • Practice solving integrals involving polynomial functions
Students and professionals in mathematics, particularly those studying calculus, as well as educators teaching integration techniques and applications in real-world scenarios.
quasar987
I am asked to calculate the double integral of the function
[tex]f(x,y) = (2x+3y)^2 = 4x^2 + 12xy + 9y^2[/tex]
on the domain defined by a triangle whose summits(?) are at (-1,0), (0,1) and (1,0). I chose to integrate from left to right. So the bounds of my integral are
[tex]\int_0^1 \int_{y-1}^{1-y} (4x^2 + 12xy + 9y^2)dxdy[/tex]
1) Vertices, not summits
2) Looks good to me
To calculate the double integral of f(x,y) in a triangle domain, we first need to set up the bounds of the integral. In this case, the triangle domain is defined by the points (-1,0), (0,1), and (1,0), so we can set up the bounds of the integral as follows:
- The outer integral will be with respect to y, and it will go from 0 to 1 since those are the y-coordinates of the points at the top and bottom of the triangle.
- The inner integral will be with respect to x, and it will go from the left side of the triangle to the right side. Since we are integrating from left to right, the left side of the triangle will be given by the equation x = y-1, and the right side will be given by the equation x = 1-y.
Plugging these bounds into the double integral, we get:
Now, we can use the properties of double integrals to split this into two separate integrals:
\int_0^1 \int_{y-1}^{1-y} 4x^2dxdy + \int_0^1 \int_{y-1}^{1-y} 12xydxdy + \int_0^1 \int_{y-1}^{1-y} 9y^2dxdy
From here, we can easily integrate each of these individual integrals using the power rule for integration. This will give us:
\int_0^1 \left[ \frac{4x^3}{3} + 6x^2y + 9xy^2 \right]_{y-1}^{1-y} dy
Simplifying this further, we get:
\int_0^1 \left[ \frac{4(1-y)^3}{3} + 6(1-y)^2y + 9(1-y)y^2 - \frac{4(y-1)^3}{3} - 6(y-1)^2y - 9(y-1)y^2 \right] dy
Now, we can simplify the expressions inside the brackets and combine like terms:
\int_0^1 \
