Help with nonlinear 1st order ODE
  • Context: Graduate
  • Thread starter Thread starter X89codered89X
    Nonlinear Ode
The discussion revolves around solving a nonlinear first-order ordinary differential equation (ODE) given by {x}^{.}(t) = x^{2} + t^{2} with the initial condition x(0) = 0. Participants explore methods to demonstrate that the solution "blows up" before t = 1, while also considering the behavior of the solution and related functions.
  • One participant expresses uncertainty about the method to solve the ODE, questioning the validity of integrating with respect to x while t varies.
  • Another participant identifies the ODE as a Riccati type and suggests a transformation to a Bessel-type equation, proposing the use of Bessel functions to analyze the solution's behavior.
  • A participant seeks clarification on how to use the Bessel function results to demonstrate the explosion of the solution at t = 1, indicating that they do not need a complete solution.
  • One participant reports that their results indicate the solution does not blow up at t = 1, but rather at t ≈ 2.003147, which corresponds to the first root of the Bessel function of order -1/4.
Participants do not reach a consensus on the behavior of the solution, with differing views on when the solution blows up, indicating ongoing disagreement and exploration of the topic.
There are unresolved assumptions regarding the choice of comparison functions and the implications of the Bessel function results on the original ODE's behavior.
X89codered89X
So I'm supposed to prove that
[itex]{x}^{.}(t) = x^{2}+ t^{2}[/itex] with [itex]x(0) = 0[/itex] blows up before [itex]t = 1[/itex].
I'm not sure what method to use to solve I've tried setting up an integral such as [itex]\int^{x(t)}_{x(0)} \frac{dx}{x^{2}+t^{2}} = \int^{t}_{0} dt[/itex] but I didn't think I could do this since 't' is varying over time on the Left Hand side and I'm integrating with respect to x.
The only other clue I have is to use a comparison ODE, which was mentioned in class, in which would use a function, say... [itex]g^{.}(t) =< x^{.}(t)[/itex] which was easier to work with. If I were able to prove that the lesser function exploded before [itex]t= 1[/itex], then logically the greater one explodes. The thing is I don't know what function I would even chose to set this up. Any ideas?
..and Thank youuuuu.
Hello !
The ODE is on the Riccati kind. First let x(t) = -y'/y
leading to y''+t²y=0
which is on the Bessel kind
y(t) = sqrt(t)*(c1*J(k,X)+c2*J(-k,X) )
J(k,X) is the Bessel function of order k
k=1/4
X=t²/2
k=1/4
Right OK! can I then substitute that back in somehow to show that it explodes at t -> 1? I don't necessarily need to get it solved. Just know how it behaves.
From my results it doesn't "explodes" close to t=1, but at t=2.003147 which is the first root of the BesselJ function of order -1/4.
  • · Replies 0 ·
