Thermal Expansion of Brass piston in Steel cylinder
The discussion focuses on designing brass pistons to fit within steel cylinders, specifically addressing the thermal expansion of both materials between 20.0 degrees Celsius and 150.0 degrees Celsius. The coefficients of linear expansion for brass and steel are 2 x 10^-5 and 1.2 x 10^-5, respectively. To ensure proper operation, the minimum diameter of the steel cylinder must accommodate the expanded brass piston at 150.0 degrees Celsius, necessitating calculations using the area and volume expansion equations. The user seeks guidance on relating the expansion of the piston and cylinder effectively.
  • Understanding of thermal expansion concepts, specifically linear and volume expansion.
  • Familiarity with the coefficients of linear and volume expansion for materials.
  • Basic knowledge of geometry related to cylinders and their volume calculations.
  • Ability to perform calculations involving temperature changes and material properties.
  • Calculate the final diameter of the brass piston at 150.0 degrees Celsius using linear expansion formulas.
  • Determine the required inner diameter of the steel cylinder at 20.0 degrees Celsius to accommodate the expanded piston.
  • Explore the implications of material properties on thermal expansion in engineering design.
  • Review examples of thermal expansion calculations in mechanical engineering contexts.
Mechanical engineers, materials scientists, and students involved in thermodynamics or mechanical design who need to understand the implications of thermal expansion in component design.
NickP89
You have been assigned to design brass pistons to slide inside steel cylinders. The engines in which these pistons will be used will operate between 20.0 degrees Celsius and 150.0 degrees Celsius. Assume that the coefficients of expansion are constant over this temperature range.
If the cylindrical pistons are 25.000 cm in diameter at 20.0 degrees C, what should be the minimum diameter of the cylinders at that temperature so the pistons will operate at 150.0 degree C?
ΔV=βV(Initial)ΔT for Volume Expansion, where β is the coefficient of volume expansion
ΔA=2αA(initial)ΔT for Area Expansion, where α is the coefficient of linear expansion
The coefficient of volume expansion for brass is 6*10^-5 and for steel is 3.6*10^-5. The coefficient of linear expansion for brass is 2*10^-5 and for steel is 1.2*10^-5.
Volume of cylinder: pi*r^2*h
I am not sure if I have to use the volume expansion equation or the area expansion equation. I understand that the cylinders are solids and would undergo volume expansion but I wasn't given a height of the cylinder. I tried assigning a value of 1cm for the height but I don't think that's O.K. I tried using the area expansion but also got numbers that were not realistic.
Attempt at solution:
ΔV=(6*10^-5)(130K)(pi*(12.5cm)^2*h)=(3.83cm)h for the brass piston
The steel cylinder would also expand:
ΔV=(3.6*10^-5)(130K)(pi*r^2*h)=0.0147*r^2*h
I really don't know where to go from here, I know that the brass will expand more than the steel, and that the steel cylinder certainly has to be bigger than the brass piston at 20 degrees celsius, but I don't know how to relate the two. Any direction and help will be appreciated very much.
Isn't the case that the when the brass piston reaches 150 degree celsius, then the inner diameter of the steel cylinder(also at 150 deg) must be the same as the outer diameter of the piston? There will be no gap between the piston and the cylinder at 150 deg, but there will be at 20 deg. You must design the cylinder so that the brass piston is allowed to expand freely?
  • · Replies 16 ·
