Can anyone offer advice on vibration in machine tool?
  • Thread starter Thread starter fastline
    Machine Vibration
The discussion centers on addressing vibration issues in a machine tool transmission, which has persisted for years and affects machined parts. The transmission, which is mounted on isolators and powered by cog belts, exhibits low-frequency vibrations between 50-200 Hz. A temporary solution involves adding weight to the point of greatest deflection to shift natural frequencies and reduce vibration amplitude. For a long-term fix, designing a tuned absorber is recommended.
  • Understanding of vibration analysis and frequency response
  • Familiarity with mechanical isolators and their applications
  • Knowledge of tuned absorbers and their design principles
  • Experience with weight distribution and its effects on vibration
  • Research fluid damping techniques for vibration reduction
  • Learn about designing tuned absorbers for specific frequency ranges
  • Investigate methods for measuring vibration amplitude and frequency response
  • Explore advanced isolation techniques for machine tools
Mechanical engineers, vibration analysts, maintenance technicians, and anyone involved in optimizing machine tool performance and reducing vibration issues.
fastline
We have a vibration from a transmission that is showing up in some machined parts. We know the transmission needs to come apart but will need to schedule it for this summer. Has been this way for years. We need to find a quick remedy to at least reduce the problems. Transmission already sits on isolators. Trans power is transferred through cog belts. We have added about 50lb of lead which is helping but not enough.
Frequencies change with speed but are rather low in general. 50-200hz. Have no experience designing dampers. Wondering about fluid damping or anything fairly modular so we can tweak it into a certain frequency and at least get a good finish for now.
Thanks
A long term fix I would say you should try to design a tuned absorber.
For right now though, if you can determine the point where there is the greatest deflection due to the vibration is; try sticking a weight there. By doing that you'll shift you natural frequencies towards the left, and also the weight will create a higher moment of inertia reducing the amplitude of the vibration.
