How Do You Calculate the Specific Heat of a Nitrogen Molecule at 13.6K?
The discussion revolves around estimating the specific heat of a nitrogen molecule at a temperature of 13.6K, focusing on the appropriate equations and methods to approach the problem.
  • The original poster attempts to apply a specific equation for calculating the specific heat but expresses uncertainty about determining the frequency of oscillation for diatomic molecules. Other participants provide alternative formulas and question the applicability of the original equation.
Participants are exploring various approaches to the problem, with some providing alternative equations and discussing their relevance. There is a lack of consensus on the best method to find the frequency needed for the calculation, and some participants are questioning the assumptions made in the original approach.
There is mention of different stages of thermodynamics and the potential for varying accuracy in specific heat calculations. The original poster notes that their course context is Quantum Physics, which influences their approach to the problem.
Finaid
Estimate the precise value for the specific heat of a nitrogen molecule at T=13.6K
I'm pretty sure the correct equation is:
Cp = (7/2)*R + R((hv)/(kT))2 *((e(hv/kT))/(e(hv/kT)-1)2
So R=8.314 J K-1mol-1
T=13.6K
h=6.626*10-34m2kg s-1
k=2pi/λ
v= ?
Well, I know that diatomic molecules oscillate at a single characteristic frequency,v, but I'm not sure how to find what frequency that is and without it I can't finish the equation. I figure if I had the frequency, I could find λ or vice versa but I need both to finish the problem. Or am I approaching this in too straightforward a manner?
Any help or confirmation that I'm at least headed in the right direction would be appreciated.
Such equations are always approximate and of questionable value to physicists, chemists and engineers from a practical view.
Bryant in 1934 came up with a formula for molar specific heat at constant pressure:
cp = a + bT + cT2
For N2 he gave
a = 6.30 cal/mole-K
b = 1.819e-3 cal/mole-K
c = -0.345e-6 cal/mole-K.
It depends on what stage of thermodynamics you're at. Modern expressions have indeed increased the accuracy of this parameter. Afraid I'm not knowledgeable about them.
Of course, to get the specific heat of a single molecule you have to divide by Avogadro's number.
Well, I'm a 3rd year Physics Undergrad and this is a question for my Quantum Physics class, not Thermodynamics. I think that's why I have to use the equation above and in the derivation I have for that, Avogadro's number cancels out somewhere along the way. There's a section in my lecture notes deriving this equation for specific heat of a diatomic molecule, but no examples or mention of how to find v.
Thanks for giving it a go anyway!
Could I put the frequency v=c/λ? I don't know whether I'm able to assume the conditions for a vacuum, but it would cancel out λ, the wavelength and then ((e(hv/kT))/(e(hv/kT)-1) would go to zero, which would leave Cp=7R/2. This doesn't seem right but it's more than I had yesterday.
You're in PH356, yeah?
Yes, sadly.
10K
