| New Reply |
is the surface tension of a liquid droplet stable? |
Share Thread | Thread Tools |
| Jan31-12, 03:32 PM | #1 |
Hi all,
Typically, we know that the surface tension for water is about 72mN/m at RT. so do this mean that the surface tension over the whole droplet is exactly the same? Moreover, we know that the Laplace pressure may be different over the whole droplet as the curvature in different parts might be different. How to explain those phenomena? Waits for your wisdom, and thanks for any help! |
| Jan31-12, 07:20 PM | #2 |
Recognitions:
the value you quote is for pure water- surface contamination, surfactants, or other solutes will drastically lower the value.
The curvature is allowed to vary with, for example, height in a gravitational field (hydrostatic pressure head). This does not change the interfacial energy, which is a property of the two phases. The interfacial energy can support spatial gradients (Marangoni flow, for example) if there is a temperature or concentration gradient. does that help? |
| New Reply |
| Tags |
| laplace pressure, surface tension |
| Thread Tools | |
Similar Threads for: is the surface tension of a liquid droplet stable?
| Free surface of liquid. | General Physics | 9 | ||
| liquid tension problem | Advanced Physics Homework | 3 | ||
| relationship between surface tension and the shape of a liquid drop | Chemistry | 4 | ||
| Effect of surface tension on path of liquid | Classical Physics | 0 | ||
| Surface Tension of an electrically charged droplet | General Physics | 2 | ||
