Type of image from an afocal optical system
The discussion revolves around the nature of images produced by afocal optical systems, particularly in the context of extended objects. Participants explore whether these systems produce real or virtual images and provide examples, including the case of a car located 30 meters away.
  • One participant questions whether an afocal system produces a real or virtual image when the object is an extended object.
  • Another participant references a book chapter suggesting that afocal systems can form real images, raising confusion about how this occurs given that emerging rays are parallel.
  • It is proposed that the presence of the human eye is necessary for image formation, as the eye focuses the parallel rays on the retina to create a real image.
  • A participant mentions familiarity with telescopes as examples of afocal systems, noting that an eyepiece is required for image formation.
  • One participant revises their earlier claim, stating that while distant objects produce parallel rays, closer objects result in diverging rays, allowing for the possibility of real images without changing transverse magnification.
  • Another participant asserts that images from afocal systems are always real and distinguishes between two types of afocal systems: Keplerian and Laguerre, specifying the lens configurations involved.
Participants express differing views on whether afocal systems can produce real images, with some asserting that they always do, while others highlight conditions under which this may not be the case. The discussion remains unresolved with multiple competing perspectives.
There are limitations regarding the assumptions made about the distance of the object and the definitions of real and virtual images in the context of afocal systems. The discussion also reflects varying interpretations of how image formation occurs in these systems.
fisico30
Hello Forum,
what type of image does an afocal system produce if the object is an extended object? A real or virtual image?
Any example? Say a car is located 30 meters away...
Thanks
fisico30
Science news on Phys.org
I just found a book chapter, AFOCAL SYSTEMS, by William B. Wetherell...
It seems that afocal system can form real images...but how, if the emerging rays are parallel?
fisico30
I guess this systems always imply that the human eye is there...that is the only way an image will form: each point on the object will have parallel rays emerging from the system.
The eye optical system will focus those bundles of rays on the retina and form a real image...
The only afocal systems I am familiar with are telescopes; an eyepiece is required to form an image.
Well, I was wrong in what I said.
If the object is very far, the input rays are parallel and the output rays are parallel too.
But if the object is close by, the rays entering the afocal system are diverging. Real images are possible. Moving the object along the axis does not change the transverse magnification, i.e. the image size...
See figure 1D at http://www.mntp.pitt.edu/Workshop/MNTP_Prtcp_res_2010/teaching/Optics_Chapter_95_LanniKeller.pdf
thanks,
fisico30
An image from afocal system always is real. 2 types afocal; Keppler with 2 positive lens and Lagruerre with 1 positive len + 1 negative len, but f of positive always > f of negative.
  • · Replies 17 ·
