| New Reply |
I need a 12v switch to respond to a 433.92 Mhz signal |
Share Thread | Thread Tools |
| Feb2-12, 03:48 PM | #1 |
Im not an elctrical engineer but I do need a source for the above mentioned switch. I would even be open to a simple schematic. Please Help.
| Feb2-12, 04:59 PM | #2 |
Mentor
What is the source of that signal? How is it being modulated? What receive signal level do you expect from a resonant antenna at your receiver? |
| Feb2-12, 05:03 PM | #3 |
This is a simple 12v dc current that I need to interrupt in the form of a RF receiver switch that simply will close up receiving the radio signal thus allowing the voltage to pass to the accuator
| Feb2-12, 05:07 PM | #4 |
Mentor
| Feb2-12, 05:16 PM | #5 |
I cant seem to get that technical data all I can provide is the model and serial number of the source and hope you can find the specific info you need. WS4916 - DSC Wireless Heat & Smoke Detector
| Feb2-12, 08:38 PM | #6 |
For this sort of thing, you'd almost certainly need a receiver from the same company (unless you disassembled one and discovered that the wireless module is just a COTS type module that you can purchase elsewhere).
Unfortunately, the DSC RXL2-433 wireless receiver relay driver doesn't list the fire alarm as a compatible device (though it might still work, even if it's not intended for the application--I'd contact DSC to see if they'd know). Using the DSC RF5108-433 receiver module doesn't output to a user form either (it's for integration into the DSC panel). Maybe if you backed up a bit and told us what you're trying to accomplish, we can recommend an alternative? |
| New Reply |
| Thread Tools | |
Similar Threads for: I need a 12v switch to respond to a 433.92 Mhz signal
| Switch 4 wires with a Momentary switch | Electrical Engineering | 3 | ||
| AC+DC signal equation=> Then Filter AC signal= output only DC signal visible | Engineering, Comp Sci, & Technology Homework | 10 | ||
| Difference between mechanical switch and a transistor switch? | Electrical Engineering | 5 | ||
| Analog Signal Loop/Switch Control??? | Electrical Engineering | 1 | ||
| Please Respond! | Chemistry | 0 | ||
