An object attached to three springs
  • Thread starter Thread starter jd12345
    Springs
The problem involves an object of mass m attached to three springs, each with a spring constant k, arranged at equal angles of 120 degrees. The objective is to determine the time period of oscillation when the object is displaced towards one of the springs.
  • Participants discuss the need to find the restoring force as a function of displacement and consider whether this force is proportional to the displacement for small values. There are questions about how to account for the elongation of the other two springs when one is displaced.
Some participants have provided insights into the relationship between restoring force and displacement, suggesting that if the force is approximately proportional, the motion may be harmonic. However, there is acknowledgment of the complexity in determining the contributions of all three springs, indicating an ongoing exploration of the problem.
Participants note the challenge in calculating the elongation of the other two springs when one spring is displaced, highlighting the intricacies involved in the setup of the problem.
jd12345
An object of mass m is attached to three springs each of springs contant k. If the object is pushed slightly towards one of the springs find the time period of the oscillation
The springs are at equal angles from each other - which is 120 degrees.
The other ends of springs are attached to walls
2. The attempt at a solution
I have no idea how to start this question which contains three springs!
By the way, luckily i got the answer which is 2∏√(2m/3k)
please give the solution along with concept - i need to know how to solve problems where object is attached to more than one spring
hi jd12345! :smile:
find the strength of the restoring force as a function of displacement …
if that's approximately proportional to the displacement (for small values), then the motion will be harmonic, and you can easily find the period :wink:
tiny-tim said:
hi jd12345! :smile:
Its not that easy. Displacement of one of the spring agaisnt which it is pushed be x.
IT provides an upwards force kx. But its hard to find elongation of other two springs
hi jd12345! :smile:
(just got up :zzz: …)
jd12345 said:
… But its hard to find elongation of other two springs
hard?
Pythagoras could have done it!​
  • · Replies 31 ·
  • · Replies 27 ·
11K
  • · Replies 16 ·
