New Reply
f(n) = log n t = 1 seconds
Share Thread Thread Tools
Feb3-12, 11:30 PM   #1
Hi,
I'm doing this algorithm questions and i need to find the largest size n of a problem that can be solved in time t, assuming that the algorithm to solve the problem takes f(n) microseconds.
For example:
f(n) = log n
t = 1 seconds
how do i get the largest size of n in t time??
what i did is assume log is base 10, then:
lg x = y
x= 10^y
since:
f(n) = 1,000,000 microseconds
n = 10^1,000,000
am i right??
you can refer to the Q here: http://problems.datastructures.net/d...ning-times.pdf
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Feb3-12, 11:32 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by nuttynibbles View Post
Hi,
For example:
f(n) = log n
t = 1 seconds
lg x = y
x= 10^y
since:
n = 10^1,000,000
am i right??
Well, first things first, you need to read the question a bit more carefully. The opening states clearly:
Note that log n means the logarithm in base 2 of n.
Other than that, you should be on the right track.
Feb3-12, 11:38 PM   #3
oh my.. tks
if it's base 2, then:
lg2 x = y
x= 2^y
since:
n = 2^1,000,000
but why is the ans 10^3000000??
Feb4-12, 12:01 AM   #4
Recognitions:
Homework Helper Homework Help
oh my.. tks
lg2 x = y
x= 2^y
since:
n = 2^1,000,000
Do you mean 10300,000 as opposed to 103,000,000? If
[tex]2^{10^6}=10^x[/tex]
find x.
Feb4-12, 12:07 AM   #5
sorry i meant 300,000
since:
2^(10^6) = 10^x
That means:
since x = 10^6, therefore 10^x = 10^(10^6). but how do i get the value 10^300000??
Feb4-12, 12:09 AM   #6
Recognitions:
since:
2^(10^6) = 10^x
That means:
10^(2^(10^6)) correct. but how do i calculate the value 10^300000?? i'll get error on my calculator
Not... quite. You have to take the log base 10 to isolate x, and then you get 10^6 log_10(2), or about 1000000 * log_10(2). That's the x you're looking for, and it's easy to prove that it's about 300000. Then you get that 2^(10^6) is about equal to 10^(300000).
Feb4-12, 12:16 AM   #7
hi char.limit, may i know which log rule define this??
Feb4-12, 03:06 AM   #8
Recognitions:
If
[tex]a^b=c[/tex]
then
[tex]b=\log_ac[/tex]
So can you apply this to your example?
Feb4-12, 09:26 AM   #9
sorry but im actually still confuse.. i dont really understand when char.limit said i can isolate x by taking log_10 of x and i get 106 . log_10 (2).
i change x->y to avoid confusion. since the rule says:
y = log_10 x, then x=10y
if we continue from
2106 =10y
then
y = log_10(2(106)) ????
but how did char.limit get log_10(2).106??
Feb4-12, 09:50 AM   #10
Hi,
i finally understood. the rule that i was looking for is
loga(Xy) = y.loga(X)
therefore,
2106 =10y
y = 106 . log10(2)
However, i got another Q. if the Q was asked to use log2, must we give the final ans in log10??
Feb4-12, 12:50 PM   #11
Recognitions:
Hi,
therefore,
2106 =10y
y = 106 . log10(2)
Yes, that's right
No, it's not necessary. I'd usually leave the answer as it is unless I was specifically asked to convert it into that form.
Feb4-12, 09:21 PM   #12
hmm okay tks alot peeps
New Reply
Tags
logarithm
Thread Tools
