Different between integrals and Einstein summation?
The discussion explores the differences and similarities between integral notation and Einstein summation convention, focusing on their mathematical implications and contexts. It touches on theoretical aspects, notation, and practical applications in mathematics and physics.
  • Some participants suggest that integrals can be viewed as a form of summation, as indicated by the historical context of the integral symbol being derived from a stylized "S" for summation.
  • Others argue that integration and Einstein summation are fundamentally different, with integration being a limit of sums and typically involving continuous functions, while Einstein summation is used primarily in the context of tensors and finite sums in differential geometry.
  • One participant posits that both notations involve summation and can extend to infinity, questioning whether integration's limit process is the only distinguishing factor.
  • Another participant counters this by emphasizing that infinite sums are defined under strict conditions and that Einstein summation is mainly a tool for simplifying notation in vector manipulation.
  • It is noted that integration is a process for finding areas or totals over paths, while Einstein's convention is described as a practical shorthand for writing mathematical expressions.
  • A later reply highlights a potential issue with applying the summation convention in certain contexts, particularly when indices appear on both sides of an equation.
Participants express differing views on the relationship between integrals and Einstein summation, with no consensus reached. Some see connections between the two, while others maintain they are distinct concepts with different applications.
Limitations in understanding may arise from the varying definitions and contexts in which integration and summation convention are applied, as well as the potential for confusion when dealing with infinite sums versus finite sums.
ktpr2
From http://mathworld.wolfram.com i see that the integral notation was "the symbol was invented by Leibniz and chosen to be a stylized script "S" to stand for 'summation'. "
So from that i figure integrals are just summations. So what's the difference from Einstein Summation, where "repeated indices are implicitly summed over."
These two concepts have nothing to do with each other.
Integration can be viewed as the limit of sums (for example Riemann sums where the interval is divided into small intervals and the sum is over approx hieght and width - the limiting process is carried out by making the intervals smaller and smaller).
The summation convention has to do with differential geometry where you are summing over a small number of terms - in relativity, usually 4 (four dimensional space-time). The expressions involved are tensors and vectors. As you observed, there is a convention to omit the summation sign for repeated indices.
Hmmmm. So both notations carry out summation and both notations can be carried out to infinity, with any function (including one for Einstein summation that worked with smaller and smaller intervals, just like integration) ... so the only difference is that integration goes "beyond" infinity and takes the limit, while Einstein Summation does not?
Nope, you're reading to much into mere notation. Inifinite sums are only defined under very strict circumstances, and predominately summation convention is usef for finitely indexed sums, but all in all it is neither here nor there.
summation convention is just a very useful tool to let us manipulate things such as vectors and and so on:
[tex]\delta_{ij}\epsilon_{ijk}=0[/tex]
and if i recall correctly
[tex]\epsilon_{ijk}\epsilon_{ipq}=\delta_{jp}\delta_{kq} - \delta_{jq}\delta_{kp}[/tex]
Riemann integrals are, when they exist and agree, the limits of certain sums.
hmm okay that seems to jive with the end of my last post.
No it doesn't.
You'd probably need to study some linear algebra to understand the usefulness of Einstein's convention. It is just a practical way of saving some ink and effort while writing.
On the other hand, you can think of integration as a "process" by which you find the area under a curve, or the total of some quantity over a path. It has to do with processes, while Einsteins convention simply helps writing things down.
Linear algebra alos shows the problem with smmation convention: suppose T is a linear map and e_i is a basis of eigenvectors with eigen values :
Te_i= k_ie_i
without summation convention, obviously
Agreed.
On a minor note, in that case you can see that the summation convention should not be applied because there is an index i on the left hand side.
  • · Replies 24 ·
  • · Replies 22 ·
16K
  • · Replies 45 ·
