What Is the Maximum Kinetic Energy of a Photoelectron with a 400 nm Wavelength?
The maximum kinetic energy (KE max) of a photoelectron emitted from a surface with a work function of 5 eV, when illuminated by photons of 400 nm wavelength, is 0 eV. This conclusion is derived from the equation hc/(lambda) = work function + KE max. Given that the energy of the incoming photons is less than the work function, the photoelectric effect does not occur, resulting in zero kinetic energy for the emitted photoelectron.
  • Understanding of the photoelectric effect
  • Familiarity with the work function concept
  • Knowledge of the equation relating photon energy to wavelength
  • Basic grasp of electron energy levels in physics
  • Study the photoelectric effect in detail, focusing on the conditions for electron emission
  • Learn about the relationship between photon energy and wavelength using the equation E = hc/lambda
  • Investigate the implications of work function in various materials
  • Explore experimental setups for measuring photoelectron emission
Students in physics, educators teaching quantum mechanics, and researchers interested in the photoelectric effect and its applications in modern technology.
drawar
What is the maximum kinetic energy (in eV) of a photoelectron emitted when a surface, whose work function is 5eV, is illuminated by photons whose wavelength is 400 nm
1. -1.89
2. 1.89
3. 0
4. 3.1
hc/(lambda)=work function + KE max
After plugging numbers in the formula above, I get KE max=-1.89 eV, but I guess I must have done something wrong, since energy cannot be negative.
looks like your calculation is correct. Think about the physical significance.
thank you, I've figured it out :)
since lambda > lambda0, the photoelectric effect cannot occur, then KEmax = 0
  • · Replies 25 ·
