Linear Independence of \overline{w} and \overline{v} in R4/U
The discussion focuses on the linear independence of the vectors \overline{w} and \overline{v} in the context of the quotient space R4/U. The notation R4/U represents a quotient space where elements are cosets formed by adding a vector to a subspace U. The conversation clarifies that linear independence in this setting requires understanding the dimensionality of U and how cosets function, particularly in relation to linear maps and the rank-nullity theorem.
  • Understanding of quotient spaces in linear algebra
  • Familiarity with the concept of cosets
  • Knowledge of linear independence and dimensionality
  • Basic grasp of linear maps and the rank-nullity theorem
  • Study the properties of quotient spaces in linear algebra
  • Learn about cosets and their applications in vector spaces
  • Explore the rank-nullity theorem in detail
  • Investigate linear independence in higher-dimensional spaces
Students and educators in linear algebra, mathematicians analyzing vector spaces, and anyone seeking to deepen their understanding of quotient spaces and linear independence concepts.
smerhej
Well it isn't so much the problem as it is the notation used within the problem. But here is the question:
Determine whether or not [itex]\overline{w}[/itex] and [itex]\overline{v}[/itex] are linearly independent in R4/U
If v [itex]\in[/itex] V then [itex]\overline{v}[/itex] = v + U
I don't understand the notation R4/U (I understand R4 and the subspace U, but don't understand the slash between them)
it's called a "quotient space" and its elements are called "cosets" and consist of "parallel translates of a subspace by a vector".
that's why v has the overline: it's the SET:
{v+u: u in U}.
which can be thought of as the entire subspace U, moved in the direction/distance of v.
another way to think of it, is as regarding the entire space (in this case R4) losing dim(U) dimensions, by regarding all points in U as "equivalent (essentially 0)".
if dim(U) = 1, each coset is a parallel line, and you need a 3-vector to tell you "which line".
if dim(U) = 2, each coset is a parallel plane, and you need a 2 vector to tell you "which plane".
higher dimensions are harder to visualize, but the same sort of logic applies.
simce v+U is a set, v is just a "representative", and the same coset v+U can have different representatives.
one common way quotient spaces arise is in analyzing linear maps: often, we don't care about the kernel of a linear map (because everything in it just maps to the 0-vector), so we "mod it out". the resulting quotient space is isomorphic to the image space (this is pretty much equivalent to the rank-nullity theorem, but in a more abstract setting).
you calculate with elements in R4/U pretty much like you do with elements in R4, but with a "+U" along for the ride:
v+U + w+U = (v+w)+U
a(v+U) = av+U
the overline notation is a bit "cleaner" but hides some of what is going on.
  • · Replies 16 ·
