Poisson integral formula to solve other integrals
The discussion revolves around using the Poisson integral formula to compute a specific integral involving a parameter \( a \) where \( 0 < a < 1 \). The original poster presents an integral transformation and seeks to relate it to the provided formula.
  • The original poster attempts a tan substitution to simplify the integral but expresses confusion about the relationship to the Poisson integral formula. Some participants suggest reconsidering the use of the formula directly and relating the parameters appropriately.
Participants are exploring different approaches to connect the integral with the Poisson integral formula. There is acknowledgment of the original poster's attempts and suggestions for alternative methods, but no consensus has been reached on the best approach yet.
There is a mention of a second part of the question that involves integrating a function multiplied by the original integral, which adds complexity to the discussion. Participants are also considering the implications of odd functions in the context of integration.
slugbunny
Use
1) [itex]\frac{1}{2\pi}\int\limits_{-\pi}^{\pi} \frac{r_0^2 - r^2}{r_0^2 - 2rr_0cos(\theta-t) + r^2} dt = 1[/itex]
to compute the integral:
2) [itex]\int\limits_{-\pi}^{\pi} \left[1 - acos(x) \right]^{-1} dx[/itex]
for [itex]0<a<1[/itex]
[/itex].
I looked on Wolfram for help. I did a tan substitution,
[itex]u = tan\left(\frac{x}{2}\right)[/itex]
and simplified
[itex]\int\limits_{-\pi}^{\pi} \left[1 - acos(x) \right]^{-1} dx \rightarrow \int\limits_{-\pi}^{\pi} \frac{2}{u^2+1-a+au^2}dx[/itex]
It kind of looks like 1)...? I am pretty confused.
Thanks in advance!
Mate, you're supposed to use formula 1), so likely tan-substitution is not the correct way. Think about how you need to relate r, r0 to a
Thanks for the reply. Using the substitution, I got the correct answer (you base it off of the equality in 1) or something). But I can't figure out how to use integrals to solve integrals!
The second part to the question is to use the PIF to solve 2)...when the integral of 2) is multiplied by an f(x).
so,
[itex]\int \frac{f(x)}{1−acos(x)}dx[/itex]
for
[itex]f(\theta) = sin(\theta)[/itex]
When you take a hard look at the integral 1), you realize that the integral you're supposed to carry out is actually the same thing as integral 1), when you choose a appropriately (and multiply with a constant). Try rewriting it like this
[itex] \frac{1}{2\pi}(r_0^2-r^2)\int_{-\pi}^{\pi}\frac{1}{r_0^2+r^2-2rr_0\cos(\theta-t)}dt=\frac{1}{2\pi}\frac{r_0^2-r^2}{r_0^2+r^2}\int_{-\pi}^{\pi}\frac{1}{1-\frac{2rr_0}{r_0^2+r^2}\cos(\theta-t)}dt[/itex]
When you multiply by sin(theta) and integrate over theta, you will get zero because of the oddness of the integrand.
  • · Replies 105 ·
13K
  • · Replies 19 ·
  • · Replies 22 ·
