Understanding Differential Manifolds and Local Topologies in n-Dimensions
  • Context: Graduate
  • Thread starter Thread starter hedipaldi
The discussion revolves around the properties of n-dimensional differential manifolds, particularly focusing on the relationship between local topologies defined by metrics from local parametrizations and the overall topology of the manifold. Participants explore concepts related to differentiable structures, metric spaces, and the conditions under which manifolds can be metrized.
  • One participant suggests that n-dimensional differential manifolds may have different local topologies defined by metrics from local parametrizations.
  • Another participant counters that local coordinate systems define the same topology on overlaps and the same differentiable structure.
  • A different viewpoint states that the manifold as a whole is a metric space with a global topology generated by open balls in the metric.
  • There is a discussion about the definition of a manifold, with one participant noting that it must be locally homeomorphic to ℝn, thus inheriting topology from it.
  • Another participant mentions that standard conditions for a topological space to be a manifold guarantee its metrizability, referencing Urysohn's metrization theorem.
  • Concerns are raised about the claim that all manifolds have their topology determined by path length, with clarification that this is true only when a Riemannian metric is present.
  • A distinction is made between a Riemannian metric (or metric tensor) and a metric as a distance function, with emphasis on how a Riemannian metric gives rise to a distance function on the manifold.
Participants express differing views on the nature of local topologies in differential manifolds, the implications of Riemannian metrics, and the conditions under which manifolds can be metrized. The discussion remains unresolved with multiple competing perspectives presented.
Some participants note the importance of specific conditions such as second countability, paracompactness, and Hausdorff properties in the context of metrization, but these conditions are not universally accepted as applicable to all manifolds discussed.
hedipaldi
Hi everebody,
I want to clear something.An n-dimensional differential manifoled is locally endowed by topologies defined by the metrices from the local parametrisations.I suppose that these topologies may all be different.Am i right?If i am mistaken ,then why?
thank's
i think you are mistaken. the local coordinate systems not only define the same topology on overlaps but also the same differentiable structure.
I'm not sure I understand your question, but the manifold as a whole is a metric space, i.e., it has a global/general topology generated by ( with topological basis ) the open balls in the metric, where the distance is given by the length of the shortest path between points.
hedipaldi said:
Hi everebody,
thank's
It follows from definition on manifold. It must be locally homeomorphic to ℝn, so it inherits topology from there. A subset O of manifold is open iff for every chart (U; γ) of M a coordinate representation of intersection of O and U is open in ℝn.
I might have not put it in the best way, but in fact its quite simple.
You don't even have to define manifold as a topological space, but as a set with an atlas, and topology follows from that.
Ordinary manifold shouldn't be a metric space I believe. You cannot measure lenghts on it.
The standard definition/conditions for a topological space to be a manifold I know of, guarantees its metrizability: 2nd countable, paracompact, Hausdorff, etc. and then use some variants of Urysohn metrization theorem to guarantee its metrizable. I'll look up some refs. for a more detailed argument.
I just checked Wiki and they state that 2nd countable manifolds are metrizable. Urysohn's metrization says that Hausdorff +2nd countable +regular => metrizable. In my use, these conditions are assumed..
Still, I may be off in stating that in all manifolds the topology is determined by path length,(so that open balls B(p,r) are given by path length) only when we have a Riemannian metric, so that the manifold becomes a(n) intrinsic length space. Maybe someone can double-check on that. See the 'examples' section in:
http://en.wikipedia.org/wiki/Length_space , for more, and a better explanation.
Basically, a Riemannian structure on M allows us to define the length of paths
between points. Then we define , for x,y in M , d_L(x,y) := inf {L(γ): γ:I→M; γ(0)=a,
γ(1)=b} , where L is the length of the path. One can show this d_L is a metric, and the topology determined by this metric ( i.e., base elements are open balls B(p,r)) agrees with the intrinsic topology of the manifold.
And I think we only need the manifold to be C^1 , for it to allow a Riemannian structure.
I capitulate, since I don't understand this area, but I think you mistook metric and metrizable space.
Well, I am making a distinction between the Riemannian metric --more accurately metric tensor-- and a metric as a distance function in the manifold, if that is what you meant. My point is that a Riemannian metric gives rise to a distance function metric on the manifold by the method I stated in my previous post.
Thank's all for your constructive replies
  • · Replies 20 ·
  • · Replies 40 ·
9K
